Page 96 of 854 FirstFirst ... 4686919293949596979899100101106146196596 ... LastLast
Results 1,426 to 1,440 of 12803
  1. #1426
    Oct 2008
    On Earth
    Quote Originally Posted by LuisAndre View Post
    No my friend... You dont understand... And when i say You, I mean a lot of You... There is no fuse bomb. You can't downgrade to any version... but you can't upgrade either, simply because the cracked version will mark interface as an unregistered cable on the AT eeprom area... Why it still works on a cracked version? because the cracked version bypass that check. The right way to say it is: you can't use an original version after use a cracked one...
    And you can use a previous version... If you use a cracked previous version. Now you know why yellow guys sells the crap cable and provide software version 708, 805,908,912 and 10.6. ALL CRACKED and with the warning : Do not use this crap cable with any other software...
    (Sorry, i don't like Mr. Wang.)
    And good luck to you too.
    That's what I wanna said. Thanks.
    When I use original version of 10.6.0 with BL tool and I told you that it works with your loader.
    But I can't downgrade to original 10.6.0 sw
    That's it. If I will need a tool to change the sw I will buy a genuine tool.
    Good luck
  2. #1427
    angelx431's Avatar
    Sep 2010
    BG Sofia Madrid
    Quote Originally Posted by nkstyle View Post
    Can you share this backup?
    I also trying repair FT232R with FT_Prog but i dont have the backup.
    vcds 10.6.2 ft232rl.ept
  3. #1428
    Top Poster + mladen76's Avatar
    By the see
    First thanks for the detaild explanation,and have to ask beginer question couse there is a lot information I dont understand,that crap cable you talk whit all the versions the chines send 708, 805,908,912 and 10.6 my antivirus only recognize v 908 as virus,but my question is,can I use this cable to do vw diagnostic,long coding.... and what software to use??
  4. #1429
    After is used your loader any other version (new or old) will destroy the eeprom
    Also if the software knows it's modded can not say what would do - wrong DTC, codding, long codding and etc.
    Chinese use cracked versions started form 908 and mainly from 10.6x.
  5. #1430
    I have been testing loader several times and VCDS is still alive My configuration is VCDS 908 with flash 1.81.
  6. #1431
    Mar 2011
    I just recieved a vag106 cable from china. The guy put a note in to message him when i get it and he would send the file. I have, bu i have to wait probably till tomorrow due to time difference.
    Does anyone have this file? im guessing its not going to be the original one from ross-tech site.
    Edit: it has RL chip
  7. #1432
    Quote Originally Posted by mbenz1 View Post
    will work badly with cracked only soft
  8. #1433
    Mar 2011
    Quote Originally Posted by tk500 View Post
    I don't understand. Do you mean I must not use cracked software with this cable?
  9. #1434
    Junior Member max4ever's Avatar
    Romania
    Exactly M8! Don't use cracked software for your interface, otherwise, your interface its gone!
  10. #1435
    Oct 2008
    On Earth
    With cracked sw works badly but you don't have anythingelse to do. This is it.
    Good luck
  11. #1436
    Mar 2011
    Ok cheers, so should i use original software from ross-tech only?
    Where from? which version? 10.6 or 10.6.3?
    Sorry about all the questions i just dont want to burn this cable.
  12. #1437
    Romania
    Only 10.6 or old version!
  13. #1438
    Mar 2011
    Quote Originally Posted by max4ever View Post
    Ok. Thanks but I can't find the original 10.6.0 without crack anywhere. Rosstech only show 10.6.3 on their site.
  14. #1439
    Oct 2008
    On Earth
    M8 if you have a tool with Ft232RL inside do not use original version of VCDS.
    Use just cracked chinese softwears.
    Original softwears from ross-tech works with tools with FT232BL or BM inside.
    If I said someting wrong please forgive me.
    Good luck
  15. #1440
    Mar 2011
    Ok Thanks, i will wait till the guy sends me the software.
    There seems to be a lot of conflicting information given on this thread
