Page 99 of 854 FirstFirst ... 4989949596979899100101102103104109149199599 ... LastLast
Results 1,471 to 1,485 of 12803
  1. #1471
    Mar 2011
    Hi Friend s i have problem with FT232BL Atmega162
  2. #1472
    Mar 2011
    HELP !!!!
    I have program Atmega162 with UPA when I Test
    Port Status: OK
    Interface: Found !
    Status: Not plugged into Car !
    My Led Blink one way when I conect 12v
  3. #1473
    Oct 2008
    On Earth
    Plug it into the car and see whats next.
    Good luck
  4. #1474
    May 2009
    Quote Originally Posted by DiagService View Post
    HELP !!!!
    Port Status: OK
    Interface: Found !
    As have put fuse in UPA ? The especial way is necessary
    ISIS 2.8, ICOM, ISSS, ISID
  5. #1475
    DK Veteran KenshinPT's Avatar
    PT
    HELP !!!!
    Port Status: OK
    Interface: Found !
    WRONG:
    Make sure that your power supply has enough current to power up the ATMEGA.
    I had that problem once... for example: if I power up directly the ATMEGA with the 5Volt from USBasp I get the blinking red problem... I don't know why but i thinks it doesn't have enough current.
    CORRECT (thanks to Xoom)
    Make sure you have 12V at the input of the regulator (7805)
    Did it help? Push Thanks below
  6. #1476
    xoom's Avatar
    Ylakiai
    it not current problem its becouse transistors dont have 12v so ATF dont get signal.. so Atmega thinks that its error
  7. #1477
    DK Veteran mishu_b's Avatar
    Land of Choice!
    HELP !!!!
    Port Status: OK
    Interface: Found !
    my dear friend,
    You might have two problems, as far as I can see from your posts:
    1. fuses program - did you programed fuses accordingly?
    2. your dump it doesn't fit to your interface.
    all the best
  8. #1478
    Mar 2011
    I have erase chip, program flash program Fuse Bits, when I conect to
    Test: Un plugged into Car !
    Today I have change eeprom in VCDS 93c46 and nothing
    If you have any idea REPLAY
    Thanks All
  9. #1479
    Portugal
    Thanks All
    When you test the cable is in the car? If not, disconnect the wires that flashes your Atmega and try again.
  10. #1480
    Land of Choice!
    first question:
    after re-flash the MCu do you get the LED on? (doesn't matter the color)
    atb
  11. #1481
    Mar 2011
    after re-flash Diod blikn once
  12. #1482
    Mar 2011
    When you have good Dump From Atmega162 FT232BL and eeprom 93c46 can you Send to my.
    If you're working with UPA Re-flash Atmega162 can you send to my manuals
    I have no more ideas
    Thank s ALL
  13. #1483
    Land of Choice!
    2 possible issues as I told few lines above.
    firs look carefully to fuse and afterwords try with a different dump.
    all the best!
  14. #1484
    Mar 2011
    I have change 7805 Regulator for 12V and eeprom 93c46
    I read and flash Atmega162 and program fuse bits with UPA programer, when I conect 12V my LED blink one way
  15. #1485
    PT
    One important question:
    Is your cable based in the FTDI232BL or FTDI232RL?
    (FTDI232BL and FTDI232BM are the same - BL is Lead Free and the other isn't).
    If you have the RL version you need to do some modifications in the PCB and you need to reflash the GAL.
