....so, 10.6 doesnt "know"old blacklisted serials?????
If freedom is outlawed, only outlaws will have freedom!!!!
the 10.6.0 know old blackisted serial...
but with a 10.6.0 real DUMP (so new serial) you can use xxx.xx -> 10.6.0 Version
RIGHT! my bad! i didnt understood well!
so, if someone manage to patch the serial checking on the 10.6 software, or un-blacklist all older serials, you can use all the software on any version of interfaces!
...if it would be only that simple....!
the protection its very complex!
interface its checking the license all the time....! every time you press a button , license its checked!
Farnell United Kingdom | world-leading distributor of electronic and maintenance, repair and operations products.
Electronic Components Distributor | DigiKey Corp. | US Home Page
Mouser Electronics - Electronic Component Distributor
RS Components | Electronic and Electrical Components
http://www.avnet.com/
US - Electronic Components Distributor | Newark.com
Electronic Components from the Best - Future Electronics
chip1stop - One Stop Shopping Procurement Service for Electronic Components -
Can somebody tell me what could happened, after when I reflash interface with 908(arash dump)-232BL inside, and after connection to the car the led is off, no power. I changed stabilizer 7805 and still to same. Cable still recognaized as Ross Tech.
If the programming of the ATMEGA goes wrong basicaly the cable is dead
However, it is deteted as Ross Tech HEX because that information is stored in the FTDI's External EEPROM (93Cx6).
Try reflashing the ATMEGA again and see at the end of the programming if you get a successful message.
Good luck.
PS: Your dump file can also be corrupted somehow. Did you change something on it? Get another clean copy of it just to make sure.
When I connected cable for relishing the led is not blinking like before. I didn't change anything, and I used to same dump. I'll try to flash one more time with different dump.
So is the cable completly dead, or when replace new atmega and program it again will be ok?
Like I said... maybe its a dump problem or a faulty programming.
If you have the information in the device manager that the cable is recognized has RossTech-HEX, FT232BL and 93Cx6 must be OK.
- Try to reflash again the ATMEGA and the FTDI's external EEPROM (93Cx6).
- Check with a multimeter if you have 5V in ATMEGA's Vcc.
So in theory if something went wrong during flashing, and cable is dead now, if I'll change Atmega162 on new one and corectly flash with good dump will cable back to work?
THX for all
