Page 345 of 854 FirstFirst ... 245295335340341342343344345346347348349350355395445845 ... LastLast
Results 5,161 to 5,175 of 12803
  1. #5161
    Mar 2017
    Smile
    Quote Originally Posted by kolimer View Post
    Announcing VCDSLoader_v2 with fixed reported issues
    http://ge.tt/3q0nKAm2
    https://www.sendspace.com/file/6dllpa
    http://www115.zippyshare.com/v/mLxhZ1oB/file.html
    Write FLASH and EEPROM from archive or use VAGCOM_EEWrite if you have correct bootloader, install latest vcds of any language of your choice, copy VCDSLoader and enjoy.
    Fixed VAGCOM_EEWrite for HW 0x44 and failed update from vcds
    Fixed FTDI BM/BL
    Hi kolimer,
    v2 works fine on VCDS 17.8.0 PCI German version on Windows Xp 32bit and Win7 64 bit.
    Great job dude
  2. The Following User Says Thank You to EpicFail78 For This Useful Post:
    nagyelek1982 (19th August, 2017)
  3. #5162
    Raimax's Avatar
    Nov 2013
    LT
    Before the latest version of the program did not work. Chip is BL. With v2 version everything is fine
    Thank you Kolimer
  4. #5163
    Apr 2008
    Hello peeps is it worth me buying one of these
    Look at this on eBay http://www.ebay.co.uk/itm/272810527761
    And will I be able to keep it going with the flash files on this thread? And update it??
    Or is it best just to buy a cable and get software "elsewhere". If so what cable do people find works best ?
  5. #5164
    May 2017
    Hi all
    I have my old version 16.8 and it didnt work. I can try repaire it . This is PCB but i dont know how i can connect it to prgramer USBasp ? Anybody can describe me PINout on my PCB ? Or i must solder to pin to ATMEGA ?
    It is with STC chip, and from info manual i know that i must cut wire to resistor R50. But after programming again connect ?
    But how connect interface to programmer ? Pin on PCB describe is as G T R V ? But how connect MOSI MISO SCK RST GND VCC ?
  6. #5165
    Jan 2017
    Quote Originally Posted by thegoat View Post
    Too expensive. Buy this one http://www.obd2cartool.com/atmega162...t-skoda-p-1404 which has programming header.
  7. #5166
    Sep 2009
    Spain
    Hello buy a vagcom cable 17.3.1 in a chinese seller and I can not actvate the interface because it brings me loader file and generate file dat to me.
    Does anyone know how to generate that file? thanks
    http://www.obdkcan.com/vcds-1713-vag...oda_p1290.html
    Here are the files of vagcom thanks https://uploadocean.com/rd5ir6rguctn
  8. The Following User Says Thank You to pacomasi For This Useful Post:
    Papiti56 (14th January, 2018)
  9. #5167
    Dec 2009
    Hi everyone,
    I have a,nsked some questions in here the last week, but no answers.
    On the talk in here I understand that my questions would be easy to answer for many people, but no help ....
    Is this group not accepting new members?
    Wont anyone help others than their old friends?
    best regards,
  10. #5168
    Apr 2008
    Quote Originally Posted by engycz View Post
    Thanks much appreciated and ordered ������
  11. #5169
    Mar 2016
    Quote Originally Posted by pacomasi View Post
    Hi! a have a same interface, maybe from another seller....
    I contacted with the seller, and the seller forwarded me to the interface/loader manufacturer..
    and they activated my program by TeamViewer....
    and everything was fine for a few days... the cable license is gone away...
    a contacted with the seller, no answer
    And i found this topic, thanks KOLIMER i can fix my interface... this is far as the best soulution ever...
  12. #5170
    May 2017
    Hi all
    I have destroyed my old cabel VCDS 16.8 as i show in post #5164
    I flashed it succesfull by KOLIMER files and when i connect it to my car and go to test show me that interface found but not plug in to car. Look on screen. What is a problem ? What is destroyed and what i must check ? By files KOLIMER show that is version 0x46 and it is with chip STC. To flash i cut line from resistor R50 to STC chip, and after flash i connect againe line R50 to STC. It is correct ?
    Please help me. In PC is detected interface.
    Thanks for help.
  13. #5171
    You must not connect the line again on the R50.
    regards
  14. #5172
    xoom's Avatar
    Dec 2009
    Ylakiai
    That loader not working correctly.. something wrong with fault codes. Cant attach screenshot from phone..
  15. The Following User Says Thank You to xoom For This Useful Post:
    oep (25th August, 2017)
  16. #5173
    May 2017
    Quote Originally Posted by hartklep View Post
    regards
    Bingo works OK
  17. #5174
    Jul 2009
    Slovenia
    Loader works perfect.I think you writte wrong fuse.
  18. #5175
    Junior Member remyj's Avatar
    FRANCE
    Hello, you have to activate a file "request_licence.DAT" to finalize the procedure Loader-V2
    Do you have the solution to generate this key please?
