Page 496 of 847 FirstFirst ... 396446486491492493494495496497498499500501506546596 ... LastLast
Results 7,426 to 7,440 of 12705
  1. #7426
    Dec 2018
    Hi, can you help me out with the radio code for vw polo i have the VIN number ?
  2. #7427
    Feb 2018
    Hi guys, is it possible to update this vcds via USB or i must solder pin using USBASP? Thanks. photo5828195940236898502.jpgphoto5828195940236898504.jpg
  3. #7428
    Mar 2018
    Quote Originally Posted by thunderbolt96 View Post
    When will you start reading the info file in the folder from the colimer? The shaman is visually determining whether the bootloader is unlocked has gone to work as a Santa Claus)))
    https://drive.google.com/drive/folde...Un?usp=sharing
  4. #7429
    May 2010
    Not always HW type (44 or 46) is correctly determined by Koli's soft
    That because chineses write incorrect version of flask inside Atmega. If chineses (or someone else) write firmware flash for "46" HW inside "44" HW, the soft will report "46" and viceversa. So, the best solution for knoing is to open the case and check the HW by "your eyes"
  5. The Following 3 Users Say Thank You to liviudiaconu For This Useful Post:
    fantomel (22nd December, 2018), LostAngel (9th March, 2019), Roma77 (22nd December, 2018)
  6. #7430
    Oct 2018
    16.8.3 v7.2 18.9.0.2 updated and working well. Thank you very much!
  7. #7431
    Dec 2018
    Hello dear Digital Kaos friends. I read here for a while. Have many things solved without asking. very well explained. But.
    I can not continue without asking.
    I have a vag interface. I flashed it with ProgIsp (USBasp) and it works, for 3 - 4 times read out and erase errors, then vcds no longer recognizes the dongle. I can not find the stc chip on my board. Can someone help me?
    Here are pictures of the dongle
    Attachment 581895Attachment 581895Attachment 581896IMG_20181115_171655.jpgIMG_20181115_171657.jpgIMG_20181115_171830.jpg
    nice greets deepkey
  8. #7432
    Feb 2013
    Show us pics with the other side...at list I can not open it in tapatalk
  9. #7433
    Dec 2018
    crazy ... was 3 pics of each site...
  10. #7434
    Feb 2013
    Now it's ok.
    Soo, do not look for STC, it is not there, not all hw have it.
    Try again to reflash, pay attention to all stepps you need to go...choose dumps for x46 HW, double check fuse bits.
    Nice hardware you have there....where did you get it...how much you paid for?
  11. #7435
    Dec 2018
    I have flashed it very often. I do not know exactly which fuse bits have to be set. I used the progisp project. It works for a short time. It behaves as if it had a stc chip.
    Ooh, the cable is from my father, tomorrow I can ask him where. it cost, if I remember correctly, 37 €. but worth nothing if it does not work 100%.
  12. #7436
    Dec 2018
    what i do is this...
  13. #7437
    Feb 2013
    After reflash, License is OK?
    There is any antivirus program on your PC that can kill the loader? If so make some exceptions for install folder.
  14. #7438
    Dec 2018
    how i check the license?
    not antivirus on my pc.
    when I flash I do not have to swap the loader again ... it works again for 4-5 times read ...
  15. #7439
    Feb 2013
    License check:
    Cable conected to car/12V- ignition on, Options - Test - k1k2 ok, Can: Ok or not ready.
    Go to About, there is license info-( green ok, red -not ok).
  16. #7440
    Dec 2018
    thats all
    so, can is not ready
    but led is green
