Page 132 of 854 FirstFirst ... 3282122127128129130131132133134135136137142182232632 ... LastLast
Results 1,966 to 1,980 of 12803
  1. #1966
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by spychu14 View Post
    For sure your PC was connected to internet
    RL or BL based device ??
    PL :
    Jezeli ktos chcialby tanio kupic kabelek w wersji 704.1 PL lub 10.6 EN to walcie na PW.
    W razie czego naprawiam takze uszkodzone kabelki.
    Pozdro
    FT232 BL and yes it was connected to the internet
  2. #1967
    spychu14's Avatar
    May 2011
    POLAND
    So you have to use package for FT232BL.
    Search for it on previous pages or on rutracker.
    Remove software from PC, use FTCLEAN and clean registry.
    First flash 93c46 or ft232 and check if it works.
    If not you have to reflash atmega
  3. #1968
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    used MProg to reflash the FTDI devIt now shows in device manager
    or will it need to be connected to a car before i will know if its still working
  4. #1969
    Feb 2010
    can i buy VCDS separately ( software ) ?
    if yes
    IS it will work with Mongoose MFC - Toyota, Honda, Nissan, VW, and Others ?
    Mongoose MFC - Toyota, Honda, Nissan, VW, and Others | eBay
  5. #1970
    DK Veteran mishu_b's Avatar
    Jul 2009
    Land of Choice!
    Quote Originally Posted by teerak2uk View Post
    you have at least two (2) options:
    1. plug into the car
    2. supply on your desk the tool using 12V supply voltage (pin 4&5 = GND or minus (-), pin 16=VBAT or plus (+)
    with the second option you can easily check all the time if your tool works properly without running to the car.
    atb
  6. #1971
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by mishu_b View Post
    atb
    Tried it into the car today and says:
    port OK
    interface NOT FOUND
    so i suppose the atmega needs to be programmed
    which files do i need to program into this and what are the connections to use with UPA
    many thanks
  7. #1972
    DK Veteran KenshinPT's Avatar
    Mar 2010
    PT
    You need to connect to the car.
    In some cases you just get the FTDI232's EPROM erased and after a reflash with Mprog everything is OK.
    But in some cases, after you reflash the FTDI232's EPROM you can see the "Ross Tech HEX device" again in the Device Manager but the ATMEGA is compromised.. that is, the ATMEGA's dump gets changed and marked as cloned.
    In that case you need also to reflash the ATMEGA.
    Did it help? Push Thanks below
  8. #1973
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by KenshinPT View Post
    Do i need FTDI version BL? if so i cant find it and do you know the connections for UPA to atmega
    many thanks
  9. #1974
    spychu14's Avatar
    May 2011
    POLAND
    many thanks
    MOSI, MISO, SCK, RST and powersupply direct to 7805.
    VAG
  10. #1975
    Jul 2009
    Land of Choice!
    first check what are the pins allocated from UPA according to Atmega162, MOSI, MISO, SCK, RST.
    than identify the pins on your PCB at Atmega162 - these pins are the first 4 pins of the uC, and also the right order it is like obove.
    for supply use any 12V connected direct into the OBD plug: pins 4&5 GND(minus) and 16 VBAT (plus).
    be careful also to connect the GND from UPA to GND of the tool otherwise you will get an error ... this connection is to have the same refernce for supply and also for programing connections.
    atb
  11. #1976
    Member ogo777's Avatar
    Nov 2009
    croatia, zagreb
    hello people
    i have one simple question
    hot to upgrade firmware without programators
    is it possible, or no
    tnx
  12. #1977
    Apr 2010
    RF
    Quote Originally Posted by ogo777 View Post
    hello people
    ...to upgrade firmware without programators
    is it possible, or no...
    Look at a fuses map, and all you will understand. Only flash it is refreshed. But EEPROM breaks more often. Another is necessary bootloader.
  13. #1978
    Junior Member bat21's Avatar
    Mar 2010
  14. #1979
    Nov 2009
    croatia, zagreb
    ok
    how to do it?
  15. #1980
    Jul 2009
    Land of Choice!
    if your tool is genuine - you can do it just using the latest sw available on producer site.
    atb
