Page 150 of 854 FirstFirst ... 50100140145146147148149150151152153154155160200250650 ... LastLast
Results 2,236 to 2,250 of 12803
  1. #2236
    where i find a good dump for the pbc?
  2. #2237
    May 2010
    Quote Originally Posted by easyobd View Post
    Thanks very much liviudiaconu, now everything works ok. Finally I can program GAL and programmed chip matching programmed .jed file
    Can you tell me is the .jed file to same for the GAL working inside BL/BM interface and RL cable, or those files are different?
    ORIGINAL jed files are different
    What you have for rewriting the RL cable is the same with the BM versions..
  3. #2238
    DK Veteran KenshinPT's Avatar
    Mar 2010
    PT
    Hi guys!!!
    Regarding the lock fuses, of the ATMEGA162, if I set them to maximum security will I have trouble about ICSP programming?
    Can I change them just to test something without blocking the ATMEGA?
    From time to time, the VCDS detects that the ATMEGA is using a clone dump and it gets Unregistered/Shareware.
    So, I wanna try to block bootloader and other securities to prevent this modification in ATMEGA
    Regards!
    Did it help? Push Thanks below
  4. #2239
    DK Veteran bibkare's Avatar
    Feb 2010
    B & H
    Quote Originally Posted by KenshinPT View Post
    Hi guys!!!
    Regards!
    Actually what you need is a dump which would be "read-only" , lock bits prevent atmega being read out by programmer etc.. but not to be rewritten by vcds soft (left for updates), so you need to write your own code for atmega to solve this issue.
  5. #2240
    Mar 2010
    PT
    Quote Originally Posted by bibkare View Post
    Don't have these Lock Bits a Self Write Protection?
    Regards!
  6. #2241
    Mar 2010
    Great idea mate
  7. #2242
    May 2010
    Unregistered/shareware is because of serial. Serial is in eeprom.. If is possible, try to protect eeprom..
    Or.. try to set the lenght of bootloader to 0 (zero)...
    LE: Is not possible to set the lenght to 0..sorry..
  8. #2243
    Oct 2011
    thank you for the information
  9. #2244
    May 2010
    who know about VCDS with NEC 78F0513?
    Wich programmer? Dumps?
  10. #2245
    Jun 2010
    Hello,
    whats up with this NEC-Version?
    The specs are: NEC?
    D78F0513A
    1124EM404
    MYS
    PICTURE: http://s7.directupload.net/file/d/2655/368av77j_jpg.htm
    Only 10.6.0. is working, nothing else...
    Thanks!
    Last edited by erik2005; 25th October, 2011 at 06:08 PM. Reason: picture was broken
  11. #2246
    May 2010
    i have ATMEGA162V and FT232RL. and i need for a 232RL .eps
  12. #2247
    May 2010
    and in device manager appear VID0403 & PIDFA24. i dont know if it was broken or not. it`s not working with any car. the program recognise, but the car, not recognize.before try to reprogram de FDTI or ATMEGA, i must know if the clone VAG-COM 10.6 was "killed".
    P.S. sorry for 2 posts. but I do not show edit.
  13. #2248
    Oct 2008
    On Earth
    If the tool has FTDI RL it is normal to show you FA24
    Good luck
  14. #2249
    DK Veteran mishu_b's Avatar
    Jul 2009
    Land of Choice!
    Quote Originally Posted by selcosmin View Post
    if in device manager is seen correctly as ross-tech device, in this case your tool is death.
    to revive your tool you will need to reprogram the uC (Atmega 162) with a good dump.
    atb
  15. #2250
    Mar 2010
    PT
    Quote Originally Posted by erik2005 View Post
    Hello,
    The specs are: NEC?
    D78F0513A
    1124EM404
    MYS
    PICTURE: Directupload.net - D368av77j.jpg
    Thanks!
    Someone is lying here!!!! The uC as really that marking?
    The 78F0513 uC from NEC is a 64pin TQFP or 64pin FLGA
    The image you posted shows a 44pin TQFP uC...
    Something is wrong or someone is lying
    I bet the chineses marked the ATMEGA162 with a different name just to confuse other hackers :P
    Regards!
    Ken
    My mistake, I saw other version! It's 44 pin uC.
    Sorry!
