Page 156 of 854 FirstFirst ... 56106146151152153154155156157158159160161166206256656 ... LastLast
Results 2,326 to 2,340 of 12803
  1. #2326
    Oct 2008
    On Earth
    Quote Originally Posted by ovi_dk View Post
    Thank you very much for informations and quik answer,now i know
    Anyway if sobode have the VCDS 10.6.4-Roj please share with me thanx
    Best Regards
    Mate the softwear VCDS 10.6.4-Roj it is for free here diag.ro - Diagnostica la nivel profesional
    But if you ask someone to share dumps fo vCDS in Romania...I suppose that noone will do it.
    Becasue dumps in other languages then English aren't for free anywhere.
    But I will wish you good luck.
  2. #2327
    ovi_dk's Avatar
    Jul 2010
    On board
    Ok i understand,and i will try a way to buy this.
    Thank you
    If u have the answer say Thank You!!
  3. #2328
    Jul 2009
    Hello,
    I am going crazy with my vcds. A friend gave it to me as a working 9.12, but I can't get it to work at all. It does install drivers normally, as Ross-tech direct USB. The driver details show VID 0403 and PID FA24, so no problem there I suppose. I has the FT232RL chip. It also shows a short red light when I plug it into OBD and then it turns green. When I connect the cable and do the test I press save. Also tried to roll back the computer clock. Version I've tried so far gave me the following results:
    8.05 - cable test pass unplugged and no interface found when plugged in car during the test.
    9.8.0 - same, everything fine when I plug it in and do the test on the desk and when I plug it into the car - cable test fails (Port OK, Interface - not found).
    9.8.1 - timeout error.
    9.12 - timeout error.
    10.6 - cable maybe crashed error.
    Any ideas?
  4. #2329
    May 2010
    Your friend must give you the software VCDS912 specific for your interface. The soft is coming with that interface.
    Is modified soft in the case of VCDS FT232RL.
    If you haven't that soft, you must reflash and modify the interface like in tutorial of Aminebot (reflash Atmega, GAL, desolder 4 componenst and solder 3 wires). Search'it.
  5. #2330
    DK Veteran VTS_Tibi's Avatar
    Nov 2009
    Quote Originally Posted by mladen76 View Post
    First try yust reflash ftdi whit Mprog.
    If you chip is BL I am ataching file to reflash.
    I've tried MProg today, but my cable comes up as "Ross-Tech HEX USB" in the device manager, and it will not accept the drivers for the MProg as it says: "there's no information about thic compenent in this driver".
    Am I completely lost here? Or what should I do in order to reflash the FT232BL?
  6. #2331
    May 2010
    If your cable is recognized as "Ross-Tech HEX USB" and have on detail VID and PID are 0403 and FA20, you must reflash atmega.
    But, the driver is not in that .ept file. For update driver you must choose the path to the folder Rostech..
  7. #2332
    Nov 2009
    how can I check the VID / PID status?
  8. #2333
    Jun 2010
    Last working dumps?
  9. #2334
    miha99's Avatar
    Sep 2009
    EU
    VTS_Tibi"how can I check the VID / PID status?"
    In DEVICE MANAGER.
  10. #2335
    Nov 2009
    Pitesti,Romania
    Quote Originally Posted by dimitar View Post
    Or an external oscilator instead of a crystal
    can you pls explain?
  11. #2336
    Nov 2009
    Quote Originally Posted by liviudiaconu View Post
    VID_0409&PID_0058\5&340A0F05&0&1
    EDIT:
    Seems like I managed to read out the FT232BL on an other computer.
    Then I programmed the FT232BL with a dump, and now the interface is recognised in the device manager as: "ROSS TECH HEX or KEY USB interface"
    Just like it was before!
    So it's great, but when opening VCDS 10.6 I get the following error:
    "Cable not found error code -1"
    now, the VID:0403 PID:FA20 So it seems like I will have to flash the Atmega....
  12. #2337
    Nov 2009
    Pitesti,Romania
    make a custom ftdi driver to be able to reflash with mprog after that
  13. #2338
    May 2010
    VID_0409&PID_0058...
    Another VID and PID appear if atmega is rewrited by vcds (another version, internet update, etc)... Must reflash ATMEGA too, is not enough reflash only FTDI. The procedure..is here, on DK..
  14. #2339
    Nov 2009
    Okay Mate thnaks! Figured that out yesterday. Btw. this whole process seems to be really complicated, but once you've done it's pretty easy!
  15. #2340
    DK Veteran mishu_b's Avatar
    Jul 2009
    Land of Choice!
    Quote Originally Posted by erik2005 View Post
    Hello,
    whats up with this NEC-Version?
    The specs are: NEC?
    D78F0513A
    1124EM404
    MYS
    PICTURE: Directupload.net - D368av77j.jpg
    Only 10.6.0. is working, nothing else...
    Thanks!
    anyone found solution for this tool with NEC inside?
    I will try to unsolder and analyze how it is working.
    atb
