Page 226 of 854 FirstFirst ... 126176216221222223224225226227228229230231236276326726 ... LastLast
Results 3,376 to 3,390 of 12803
  1. #3376
    drpeter's Avatar
    Dec 2009
    The Netherlands
    Quote Originally Posted by mattydr67 View Post
    First of all you need to share few pics of your tool becasue it important to see what kind of PCB you have.
    That's why you read that in one type of PCB you ahev to remove 4 components to be able to flash the Atmega and in other type you don't need this.
    Second about the GAL you have two solutions, In both of them you need to unsolder the GAL/ATF (in one kind of PCB you don't need to do this ) and the best solution it is to reflash it , sodler it back and solder 3 wires ( Aminebot solution ), and it is another much easy solution , that means that you ahve to remove the GAL solder few wires and you don't need to solder the GAL/ATF back but you'll not be able to do all the functions in k-line cars ( special functions as Adaptation, Coding...etc)
    Internet solution ( we talking about the one known ) are not good in all OS installed. I develope an aplication but pple who review this said that for one it works for it dosen't.
    And in the and after you reflash the tool you need to use a loader not the original exe file of the VCDS softwear.
    There's to solutions for you:
    Buy a cheap tool from China and use it in a computer that will never have an internet connection or spend more money and buy a HQ clone which cannot be erased ever.
    Good luck
    Sorry I was confused with another cable 113, on this cable there is no GAL :-) (see pictures). But do I need to remove something on this layout before programming?
    Thanks again.
    Peter
  2. #3377
    DK Veteran bibkare's Avatar
    Feb 2010
    B & H
    Quote Originally Posted by drpeter View Post
    Thanks again.
    Peter
    It's the first time i see this design, since it's RL i think you should only reprogram atmega with 11.11.0 dump and try use it with loader. No need to remove anything. Let's see what's gonna happen. Good thing you have leads on pcb for atmega so you don't need to solder directly.
  3. #3378
    Oct 2008
    On Earth
    Thanks again.
    Peter
    Well this is the best hardwear with FTDI RL
    You don't need to usolder anything No either the ATF
    You have the flashing pads near to USB onece
    Check which are this
    From what I remember the pads starting near the USB once and item are in this order Atmega pins 3,2,1 and 4
    So you have to solder the wires from progrmmer directlly to this flashing pads and do it
    Then you have to use a loader to start the VCDS as Mr. Bibkare said
    Good luck
  4. #3379
    drpeter's Avatar
    Dec 2009
    The Netherlands
    Quote Originally Posted by bibkare View Post
    Thanks I already did that but same message interface test failed (should be ''ready''), I will experiment more when i have time. Keep you informed.
  5. #3380
    drpeter's Avatar
    Dec 2009
    The Netherlands
    Good luck
    Yes i measured the pins from atmega, programming is also not the problem, I think I need other dumps, I will try soon thanks.
  6. #3381
    Oct 2008
    On Earth
    You need the dump for , let's say VCDS 11.11.0 or 11.2 and use the right security bits ( most of the ppl use wrong security bits )
    After you reflash the Atmega, install the VCDS 11.11.0 original softwear then use the loader
    By the way you power supply GND it is soldered toghether with th GND of programmer?
    Good luck
  7. #3382
    May 2010
    Peter
    After programm the atmega and after power on the cable, LED become from red, green? Or is blinking?
  8. #3383
    drpeter's Avatar
    Dec 2009
    The Netherlands
    Quote Originally Posted by liviudiaconu View Post
    From red to green (no blinking)
  9. #3384
    drpeter's Avatar
    Dec 2009
    The Netherlands
    Good luck
    Ground is soldered together yes.
  10. #3385
    May 2010
    I suppose you know and use loader for RL versions (each version have his own loader).
    Post here a picture with test...
  11. #3386
    drpeter's Avatar
    Dec 2009
    The Netherlands
    Yes I knew but still had the wrong loader, I found another loader on this forum and now everthing is fine. Great finally it works. Thanks all. Maybe I fix my 113 cable also.
  12. #3387
    Oct 2008
    SLO
    Today I received my new VCDS which is very easy to programming.
    I solder 4 sticks to the board.
  13. #3388
    mexanico1971's Avatar
    portugal
    Hi ! anyone can tell me if tu use
    this, do I have to make any changes in com port baud !
    or something else ?!
    AVR USB Emulator debugger programmer JTAG ICE for Atmel | eBay
    computer detects the device but the program says there is no response !
    Hi all ready install the drivers for the PL-2303HX !
    please any help !
    BR
  14. #3389
    DK Veteran mishu_b's Avatar
    Jul 2009
    Land of Choice!
    use this one
    regards
  15. #3390
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by mishu_b View Post
    use this one
    regards
    Do you know whats the pinout on the h/w is I.e. reset, gnd, msio etc for connection to atmega162
