Page 241 of 854 FirstFirst ... 141191231236237238239240241242243244245246251291341741 ... LastLast
Results 3,601 to 3,615 of 12803
  1. #3601
    Junior Member Carlos_'s Avatar
    PT
    Hi people.
    I have a cable that once powered with 12v the led starts blinking red. I?ve tried to reprogram ATMEGA with latest dump 11.11.0, the programming went fine with no errors whatsoever, but once the programming is complete, the led keeps blinking red.
    BTW, the FTDI is an RL and the cable has GAL.
    Any thoughts?
  2. #3602
    Oct 2008
    On Earth
    For this tool as yours it is not enogh to just reflash Atmega
    You need to reflash GAL too
    Solder 2 wires from Atmega to GAL and one wire from FTDI to GAL
    Reflash FTDI if you need and remove 4 components from PCB ( 2 X rezistors + 1 X tranzistor + 1 X STC )
    For all this procedure you can find a tutorial right in this thread
    Good luck
  3. #3603
    xoom's Avatar
    Dec 2009
    Ylakiai
    Or could be transistors on K lines (group of 4) under 9-10 pins of OBD2 connector..
  4. #3604
    Oct 2008
    On Earth
    Quote Originally Posted by xoom View Post
    Yes that's right or any short cut
    But if you try to make a test on a car you have to see this
    K1 - short to ground
    Good luck
  5. #3605
    PT
    Quote Originally Posted by mattydr67 View Post
    Good luck
    Thank you for your reply.
    I believe this image is the schematics that you were reffering to.
    I'll try to do what's on this image, but once done, how can I reprogram GAL?
  6. #3606
    Jun 2010
    Welcome. I have the FT232RL interface, I tried a number of safe combination flash, eeprom, and configuration ftdi, I can not run any version of vcds, possessed v10.6.5 pl. Please use the hint which files to revive equipment [en or en] because I read a lot of posts and I'm still "green"
    Maciej
  7. #3607
    Oct 2008
    On Earth
    Quote Originally Posted by automaciek View Post
    Maciej
    mate
    you have a very good kind of VCDS tool with FTDI RL
    The only thisng you have to do it is to reflash Atmega with dump fro 10.6.5 Polish version and maybe the FTDI if you need to do this
    But you cannot use the VCDS 10.6.5 Polish versions with your tool if you don't have a loader, becasue of FTDI 232 RL
    Good luck
    P.S> I haven't seen a Polish loader for this VCDS 10.6.5
    but you can find for VCDS 11.11.0 English version
  8. #3608
    Jun 2010
    J win! reprograming board witch 11.11.0 and working with loader
  9. #3609
    PT
    Can someone please tell me how to reprogram GAL please? I've searched all over this thread and I found no instructions how to do it.
  10. #3610
    Oct 2008
    On Earth
    Quote Originally Posted by Carlos_ View Post
    Very easy sir
    Unsolder the GAl
    Use a good dump for it and a very good programmer for it too
    I use Genius if you want to know but you have to use what programmer you want
    Good luck
  11. #3611
    PT
    Very easy sir
    Unsolder the GAl
    Good luck
    There isn't another way instead?
    Like an homemade cable similar to the one in the tutorial to reprogram ATMEGA?
    Thank you
  12. #3612
    Oct 2008
    On Earth
    Thank you
    As I know you can a home made cable a LPT one as the one you use for reflash Atmega but I never used and you are on your own
    I allways use professional solution not homade one ( becasue many time the home made solution dosen't work and I spend time for nothing )
    As you allready know "time is money"
    Good luck
  13. #3613
    PT
    Good luck
    I understand.
    But in my case, this is an hobby for me, not a business. So I'd rather make an homemade cable to save money and to practice my soldering skills
    Thank you for your help
  14. #3614
    xoom's Avatar
    Dec 2009
    Ylakiai
    its called GALBlast not tryed by my self but seen on forum that some people use it.
  15. #3615
    Oct 2008
    On Earth
    Of course you can spend time and check your skills
    You can try to use the GALBlast solution
    It is your choice mate, I just told something from my experience adn my opinion
    In the end it is your choice
    Good luck
