Page 262 of 854 FirstFirst ... 162212252257258259260261262263264265266267272312362762 ... LastLast
Results 3,916 to 3,930 of 12803
  1. #3916
    Oct 2008
    On Earth
    Good choice
    Good luck
  2. #3917
    Quote Originally Posted by mattydr67 View Post
    Good choice
    Good luck
    MI have found another cable it's ?54 , he says it has a FT232bl chip inside it , is that the one I need ?
  3. #3918
    Feb 2013
    Hi, ca anyone help with some answers :
    1. Dump to reflash atmega for a cable with BL/BM is the same with dump used to reflah Atmega for a RL cable?
    2. Ept file,for FTDI-BM/BL, from vcds 11.11 can be used with 11.11.5 ?
    3. I post a printscreen, those security and configuration bits allows me to read dump from Atmega and to use that dump for reflash?
    Thanks.
  4. #3919
    Oct 2008
    On Earth
    Mate
    First of all the security bits are for writing the MCu not for reading
    For reading you don;t need to set the seurity bits
    Just reading
    The dump from VCDS 11.11.0 will not work with VCDS 11.11.5 just if you erase that serial from blacklist
    Good luck
  5. The Following 3 Users Say Thank You to mattydr67 For This Useful Post:
    alexm1 (13th August, 2013), paro44 (13th August, 2013), perotok (12th August, 2013)
  6. #3920
    May 2010
    Matty, edit your post: "dump from 11.11.ZERO will not WORK with 11.11.5"...
    You're inloved?
    For reading just read, but only if security/lock bits at wrote permit that.
  7. The Following 2 Users Say Thank You to liviudiaconu For This Useful Post:
    mattydr67 (13th August, 2013), paro44 (13th August, 2013)
  8. #3921
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by B19hly View Post
    For that price you can buy one that's won't erase when connected to the internet
  9. #3922
    Quote Originally Posted by teerak2uk View Post
    Were can I order one mate ? Can you pm me a link please
  10. #3923
    Feb 2013
    [QUOTE=liviudiaconu;205..
    For reading just read, but only if security/lock bits at wrote permit that.[/QUOTE]
    Well that is what I want to know , if the security/ lock bits sets like in the picture of my previous post give me the posibility to read corectly dump from Atmega?
  11. #3924
    May 2010
    Mister,
    The fusebits and security bits are setting when someone WRITE in atmega.
    If that person set like in your picture, cannot read content.
    You'll read something but not real content.
  12. The Following 3 Users Say Thank You to liviudiaconu For This Useful Post:
    alexm1 (13th August, 2013), mattydr67 (13th August, 2013), perotok (14th August, 2013)
  13. #3925
    Feb 2013
    Quote Originally Posted by liviudiaconu View Post
    Mister,
    I was not clear enough in previous post and I apologize for that.....
    I know that the bits are set when you write in atmega... that s perfectly cear; all I want to know was if the dump secured with that bits(like in the picture), after reading can be used for another cable, now I know .... .
    Thank you !
  14. #3926
    Oct 2008
    On Earth
    Mate no need to apologieze for this
    You asked but it was a littel bit confuse
    My frined liviudiaconu figure it out better then me ( for instance ) what do you wanna mean.
    What shall I wanna tell is that you'll haven't find any tool without security bts set like this
    So you cannot find tool that you can read and extract dump like this
    There's other solutions for this if you have in mind this
    Good luck
  15. #3927
    May 2010
    I think he want write tools...but, maybe he dream to find a cable unprotected...for extract dump
  16. The Following 2 Users Say Thank You to liviudiaconu For This Useful Post:
    mattydr67 (14th August, 2013), perotok (14th August, 2013)
  17. #3928
    Feb 2013
    The " story" is this: I have a cable VCDS 11.11.0( BL), brought 8 mounts ago; now a fried got a cable 11.11.5 , after a few days , the cable was detected by laptop as a " malfunction device....." . Problem was solved by changing usb cable. After, I was curios if i can read dump .... and asked for your help.
  18. #3929
    May 2010
    A, you called me. And i told you exactly the same think.
    Maybe my answer was not good enough for you.
  19. #3930
    Feb 2013
    I apreciate your answer, never doubt about it, but we must clarified this:
    I never ask no one by phone about this, definetily is a confusion.
