Page 298 of 854 FirstFirst ... 198248288293294295296297298299300301302303308348398798 ... LastLast
Results 4,456 to 4,470 of 12803
  1. #4456
    Dec 2015
    Hey all. I have an FT252BM chip, and have successfully loaded the VCDSFT232BL EPT to the cable using MProg. When I load up VCDS, it detects the cable and has no issues until I connect it to the car. From there, I hear the driver update noise from the computer, and i get issues, saying interface not found, etc. I do also understand that having a BM chip means I won't need a loader for VCDS - correct?
    I believe this is due to needing to program the atmega, no? My computer doesn't have a parallel port, so i'm unsure of any other ways to manually program it (maybe build one with a SATA cable?). I get confused a bit because I know there is a difference between the RB/RM and RL. I assume the atmega needs to be programmed even though I do not have the RL interface.
    Cable was originally an 812.4 and it still works with that version. Wondering if its possible to upgrade or if I should buy a new one.
    Thank you for your assistance!
  2. #4457
    Aug 2015
    Default not registered
    Hello, i have read most of pages in this thread and i got this cable and unregistered problem after a while (yes laptop was connected to internet but never when using cable) anyway i think it is RL cable but since it is recognizing and there is no any USB and Connectiotion problems (i can connect it to car and use it as trial DTC remove and simillar) i will try to reflash atmega i have collection of all files and tutorials with ponyprog and parrarel cable and lpt port. I am just not getting what file to flash i have file "flash_192.hex" among others but is flash and eeprom for atmega same file? I have also "vers 6 11.11.5-12.12.0_eeprom 512 rl.hex" do i need to flash that to or that is FTDI file?
    So basicly my question is what is eeprom of atmega and what is flashfile ? i dont have any .bin in my file collection.
    Cable is marked as 12.12 and came with 12.12 software , i dont know if it had any loader it had that warning to turn back time on PC and disable internet when starting software.
  3. #4458
    Jan 2016
    Hello,
    I've bought an interface with VCDS 15.7 (works fine in cars which require KKL). But as I tried it in a car which requires CAN(Seat Ibiza 2009) VCDS shows that it's not connected to a car.
    Can you tell me where to start troubleshooting?
    The interface has ATMEGA162 + 16V8B + FT232RL
    Best regrads
  4. #4459
    Senior Member makadam's Avatar
    Nov 2010
    EUROPE
    Quote Originally Posted by cardiaeur View Post
    Hello,
    Best regrads
    I have same problem and i didnt find solution to repair the cable. I change mcp2515 and other small ic near mcp without results. In the end i order new interface that work fine! If u find solution share it. Good luck
    Sent from my Redmi phone
    We can't help everyone, but... everyone can help someone!
  5. #4460
    May 2010
    You have now TWO 15.7.0, with the same programm, one working on CAN, another not?
    If YES, problem is HW. If not, and the programm is differrent...the programm.
    My 15.7.0 work ok on CAN.
  6. #4461
    Mar 2011
    sklad66.com-last board HQ clone whit online update....
  7. #4462
    May 2010
    ALL HQ clones have the same HW components/design.
  8. #4463
    Jan 2016
    Hello
    How does it look genuine VCDS cable inside, if anyone has pictures or schematic ?
  9. #4464
    Mar 2011
    http://www.filedropper.com/vcdsall
    VCDS all-dumps,instaler and more...
  10. The Following User Says Thank You to dindisa For This Useful Post:
    Jockel100 (19th April, 2016)
  11. #4465
    Dec 2012
    Quote Originally Posted by x2x View Post
    Hello
    here is ori vcds board
  12. #4466
    Mar 2011
    Quote Originally Posted by gazvts View Post
    Backside, please...
    vasq diagnost-russia
  13. #4467
    Jan 2016
    hello , my friend , i am selling VAG VCDS 15.7 interface , could you please tell me your problem ,hope i could help you
  14. #4468
    Jan 2016
    this is our vag vcds 15.7 PCB board
  15. #4469
    Feb 2016
    Anyone can help me about unregistred version ot VCDC. How to prevent vcdc to become unregistred, after working a couple of days? VCDC version is 10.6.0 some chinese clone cable.
    Thank u.
  16. #4470
    DK Veteran Overtune's Avatar
    Aug 2009
    I have purchased a VCDS that came with a loader. vcdsStart.exe is the name of the loader. I can receive updates and use this as i would with an original tool. How is this possible? Truth is it performs great both on K & CAN cars.
    TUNING FILE SERVICE SINCE 2008
