Page 321 of 854 FirstFirst ... 221271311316317318319320321322323324325326331371421821 ... LastLast
Results 4,801 to 4,815 of 12803
  1. #4801
    Sep 2015
    Quote Originally Posted by comizelu View Post
    Cannot write in 'fuse bits/settingsc'- calibration..
    To me is ffffff62 and cannot change to ffffff5e.
    I use Extreme burner.is it gonna work the same or must change.
    Thank you
    Inviato dal mio HTC One utilizzando Tapatalk
    just make this please , download AVR when i give you in link, down in my post and use images
    https://mega.nz/#!uQlj2K5D!pDRj_E1Ij...oNuQJSvxQuMCSQ
  2. The Following User Says Thank You to ivaylomezdra For This Useful Post:
    comizelu (17th April, 2017)
  3. #4802
    Apr 2016
    uk
    Works great
    Thank you ivay
  4. #4803
    Mar 2017
    Poland
    Updated to 17.1.3
    Didn't check adaptations, but looks like everything is working OK.
    Version 0x46 with FT232RL.
    Thanks!
    If someone in PL has problems with it, I can help.
  5. #4804
    Apr 2017
    Hello guys
    I have china clone VAG 12.12. FT232RL / atmega162 / MCP2515 / MCP2551I. When i connect cable to the car and run VAG i have no connection to the car - Not plugged into car.
    In picture my cable. I have tried to set something but im not sure i did it correctly.
  6. #4805
    Mar 2017
    Poland
    Use ftdi_mprog.ept and reflash atmega.
  7. The Following User Says Thank You to cinek2006 For This Useful Post:
    comizelu (22nd April, 2017)
  8. #4806
    May 2010
    see attach for FT232R. After this search good dump Atmega+installer.
  9. The Following User Says Thank You to liviudiaconu For This Useful Post:
  10. #4807
    Jun 2014
    Can you help
    I can not activate TPMS with vag com 2013 Caddy
    abs byte 16 bit 2 error
    no active
    ABS Frenler (J104) Etiketler: 1K0-907-379-60EC1F.clb Adres 03
    Par?a No GB: 1K0 907 379 BL HW: 1K0 907 379 BL
    Bileşen: ESP MK60EC1 H31 0152
    Revizyon: 00H31001
    Kodlama: 423C400D09230301420B02E69019C041310000
    Mağaza no: WSC 35110 377 00141
    VCID: 7DF19392E43044AACB-8028
    I'm getting the error below
    http://www.directupload.net/file/d/4...p7bcjd_png.htm
    Error 31: Request out of range - Coding Rejected.
  11. #4808
    Mar 2017
    Poland
    It means that module doesn't support this function.
  12. #4809
    Feb 2017
    Poland
    Guys. I need a VCDS cable with Atmega, but on aliexpress there are i think only cables with NEC chips, do you have any link with Atmega chip?
    Thanks.
  13. #4810
    Feb 2013
    Could be Nec or Atmega? I never saw this type of cable until now.
    Seller says that is working with vcds 10.6 .
  14. #4811
    Feb 2017
    Quote Originally Posted by ireun View Post
    Thanks.
    http://www.obd2cartool.com/vagcom-16...version-p-1266
    http://www.obdkcan.com/vagcom-1684-f...196_p1281.html
    It's with programming header
  15. #4812
    Feb 2017
    Quote Originally Posted by alexm1 View Post
    ATMega 99%
  16. #4813
    Aug 2009
    Default VAG-COM/VCDS EVERYTHING
    Hello dk team i am looking for good sw 16.8.4 without virus
  17. #4814
    Mar 2017
    hi Guys.
    I have buyed this china clone.
    Vagcom 17.1 full active vcds 17.1 China crack VAG 17.1 For VW Audi Seat Skoda ,V17.1 VAG Diagnose Cable support all systems diagnostics including K1,K2,CAN,UDS. full active vcds 17.1 with ATMEGA162 + FT232RL + L9637D + 16V8B.
    http://www.obd2cartool.com/vagcom-17...t-skoda-p-1341
    Can i update it to kolimer crack ?
    The hardware detection tool say no interface found!
  18. #4815
    Mar 2017
    Poland
    You need to connect it to the car first or supply +12V
  19. The Following User Says Thank You to cinek2006 For This Useful Post:
    EpicFail78 (24th April, 2017)
