Page 334 of 854 FirstFirst ... 234284324329330331332333334335336337338339344384434834 ... LastLast
Results 4,996 to 5,010 of 12803
  1. #4996
    Oct 2016
    Quote Originally Posted by cypher007 View Post
    ok downloaded 17.1.3v2 and have hooked up my 0x46 via the pin header to usbasp, and extreme burner sees the chip. how do I go about flashing it? sorry need a step by step.
    1.File->Open Flash-> select Flash1.96_HW_0x46.hex
    2.File->Open EEPROM-> select eepromavr.hex
    3.Fuse Bits/Settings
    4.Press 'Write All'
  2. The Following User Says Thank You to 34260551 For This Useful Post:
    cypher007 (5th June, 2017)
  3. #4997
    May 2010
    Quote Originally Posted by deluss View Post
    I open my cabel and inside is FT232B.
    So what i need to repair my vcds? with file is good ? I need reprog atmega one more time ?
    See attach. After ask kolimer if her solution work with B chips.
  4. The Following User Says Thank You to liviudiaconu For This Useful Post:
    bibkare (10th June, 2017)
  5. #4998
    Oct 2008
    Quote Originally Posted by 34260551 View Post
    4.Press 'Write All'
    any ideas if this will work on a 0x46 17.1 cable? if it does flash do I then use the original rosstech soft or do I need a cracked one?
    p.s. I know not to update using the rosstech software.
  6. #4999
    May 2010
    If you want use oem soft, is better to buy a oem cable, too.
  7. #5000
    Oct 2008
    4.Press 'Write All'
    that worked great. I can read codes out of my old 2003 car. Ill try a newer car later.
  8. #5001
    Jan 2017
    HongKong
    most vag cable version hw with ATMEGA + FTDI chips support reprogramming like vag 11.11.3, vag 16.8.4, one kind need active 16.8.3 only support english version ,vag 17.1.0 . other like use original software (not office cable) it is used NEC project, we test different FT232 chips, there is no obvious difference. and Thanks kolimer and other friends!!
  9. #5002
    DK Veteran deluss's Avatar
    Jun 2011
    The correct order to repair cabel is:
    1. Write VCDS BL by USB and Mprog.
    2. Next: File->Open Flash-> select Flash1.96_HW_0x44.hex
    3.File->Open EEPROM-> select eepromavr.hex
    4.Fuse Bits/Settings
    This is correct order ?
  10. #5003
    DK Veteran bibkare's Avatar
    Feb 2010
    B & H
    It doesn't matter which operation's done first, ftdi or atmega, i have a habit to do atmega first.
  11. #5004
    Feb 2010
    B & H
    Tested new dump on BL interface and used .ept from liviudiaconu few posts above, works excellent, just be sure to use proper fuses (in my case it was v44) also tested on cheap RL version - the one without GAL and 7805, was able to do long coding, autoscan and everything. Excellent work Kolimer.
    best regards
  12. #5005
    May 2017
    Can you write full manual for this...?with link for files share
  13. #5006
    Jan 2017
    Hi guys,
    finally I got my new cable of obd2cartool.com and it's working great!
    I ordered it, because I thought I killed my old 10.6.4 cable by desoldering the chip U9 „ST 8S103F2P6“ and parts R50, R51 respectively by erasing the Eeprom (which is probably the case here).
    As you can see in my post http://www.digital-kaos.co.uk/forums...=1#post2927162 the cable identified as VID_0403 & PID_FA20.
    But now the FTDI FT232BL identifies as VID_0403 & PID_6001 which is the "standard" PID I think.
    My problem is that I can't write it anymore, it is recognized either as USB <--> Serial adapter (COM3) (with FTDI drivers) or as RT Cable (with modified rt-usb driver).
    Mprog reads the device as blank, but when I try to write the Eeprom it says "Error reading device". Any other tools also can't write the chip.
    Is the chip defect or is there a possibility to write the eeprom (e.g. with linux or I read that it is possible to do it with a "real" serial port, but I couldn't find a manual for this)?
    If there is no way to write it, would it help to get a new FT232BL an replace it?
    Appreciate your answers, thanks in advance!
    ni88l3r
  14. #5007
    Feb 2013
    I had this problem a few months ago....I soldered back R50 and problem solved, actually I desoldered only STC(U9).
  15. The Following User Says Thank You to alexm1 For This Useful Post:
    ni88l3r (11th June, 2017)
  16. #5008
    Jan 2017
    Soldered R50 back in, still no luck, but thanks anyway.
    Any possibility to program the ftdi directly?
    Or should I just throw the cable in the bin, I finally jave a working cable
  17. #5009
    Jan 2016
    can somebody make full hd photos of an working device, that was flashed with kolimer files,
    (long coding, no errors)
    wanna try to build one from 2 bad clones.
    thx
  18. #5010
    Jun 2011
    Quote Originally Posted by bibkare View Post
    best regards
    Need to desolder something like R50 ?
