Page 338 of 854 FirstFirst ... 238288328333334335336337338339340341342343348388438838 ... LastLast
Results 5,056 to 5,070 of 12803
  1. #5056
    Apr 2010
    RF
    Quote Originally Posted by eliotroyano View Post
    In fact even usb port is not recognizing FTDI IC in cable, why this happends? I have try changing FTDI IC without luck at all?
    If the chip of FTDI is destroyed physically, then I will give advice, not to connect a notebook to a network of 220 volts, during diagnostics.
    If the chip of FTDI is destroyed by software.
    And if you want to protect FTDI chip from reprogram of internal EEPROM. That is necessary in the RT-USB.inf file, to add or change record:
    [FtdiBus.NT.HW.AddReg]
    HKR, "ConfigData", 0x00010001,1
    And reinstall driver.
    Or to change(add) the appropriate value in the system registry.
  2. #5057
    Aug 2009
    Quote Originally Posted by magadan View Post
    Is this possible inclusive in an interface with FT232BL with external eeprom?
    Enviado desde mi Life One X mediante Tapatalk
  3. #5058
    Apr 2010
    RF
    http://www.ftdichip.com/Support/Docu..._AN_000073.pdf.
    Part: "5.6 Disable EEPROM Writes".
    But better read all document.
    Or
    http://www.ftdichip.com/Support/Documents/AppNotes.htm
  4. #5059
    Feb 2017
    Poland
    Quote Originally Posted by BASi77 View Post
    Perhaps this chip STM32F072 in LQFP64 package, it?s easier and cheaper, fully suitable for this device. What driver is used for this cable? This is emulation of FT232 functions on the CPU or substitution at the software level?
    Also, sorry I missunderstood that. What I ment is that it is probably CPU emulation of the FTDI chip.
    The .exe file is original by Ross-Tech. Sorry once again
  5. #5060
    Jul 2017
    Quote Originally Posted by ireun View Post
    ...The .exe file is original by Ross-Tech.
    It's necessary to check whether the original rt-usb.dll and whether it changes after applying VCDS setup.exe.
  6. #5061
    May 2010
    [...] What I ment is that it is probably CPU emulation of the FTDI chip.
    In this chip are emulated more: FTDI, ATMEGA, MPC2515, GAL/ATF.
    In the neighborhood of uC and Xtal 8MHz exist another chip, SOIC8 case. I don't see if is MPC2551, 2561 or TJa1050 or..another CI for CAN.
    And, the quwstion is: what uC exist in new original HEX-V2 cables?
    If is the same or again a big "Fssssss"
    A person said me "First two times we wil show you how to make updates, after will make yourself".
    Asked and person answered "update mean COPY-PASTE one or few files"
    In my opinion, this seems to be like in "multilanguage solution.
    But another person said: "No, you only use OEM installer"..
    2 different opinions, not OK. But this is only discutions, i wait my "V2" arrive for make tests.
  7. The Following User Says Thank You to liviudiaconu For This Useful Post:
    paro44 (17th July, 2017)
  8. #5062
    Feb 2017
    Poland
    Quote Originally Posted by liviudiaconu View Post
    Hey there! This chip for CAN connection is..
    As for the original V2.. On the website of HEX Microsystems.. http://www.hex.co.za/products/ You can find a photo of the PCB of original V2..
    Indeed it uses ARM ST chip, you just can't see which one exactly.. Though it's definitely larger package that on the clone..
  9. The Following 3 Users Say Thank You to ireun For This Useful Post:
    liviudiaconu (17th July, 2017), paro44 (17th July, 2017), Qwarz (17th July, 2017)
  10. #5063
    Jul 2017
    Please , does anyone know why this cheap cable (vcds409.1) is listed as NOT compatible with Audi A4 B7 (ok with oher A4 versions) ??
    Thank you
  11. #5064
    Jul 2017
    The original HEX-V2 enumerates as an HID device and does not require a special driver and for aliexpress ?HEX-V2?, it seems to me need a ftdi driver.
  12. #5065
    May 2017
    Hi all
    I buy also from china clone VCDS Hex V2 version 17.1.3. Today recived it and start test. Connect it to my notebook with windows 10 x64 and to my car Seat exeo 2010. After connect and start diagnostic on my intrument start blink some icons and bip bip bip and saved in some modules more errors. Example in engine, abs, tyre pressure and other. Some i can delete but some can not and must use my old vcds 11.11.5
    Before connect to car my car has no errors. After that i must use my old vcds to delete errors which was generate by VCDS Hex V2.
    Please help.
  13. #5066
    Sep 2009
    That is not HEX V2.
    See test results window.
  14. #5067
    May 2017
    Ok but why not working and generate in modules in my car errors ?
    In test show Ross Tech Hex USB CAN
    Look on video what is problem...
    https://www.youtube.com/watch?v=GKxlidU0vLk
    In test on K1 show info SHORT TO +12
    I have old interface on ATMEGA chip version VCDS 11.11.5 and all works OK and on K1 and K2 and CAN show info OK.
  15. #5068
    Jul 2017
    Quote Originally Posted by pepeEL View Post
    ... china clone VCDS Hex V2 version 17.1.3. Today recived it and start test. ...
    Could you copy the installation CD from the cable "HEX-V2" on ge.tt and post the link.
  16. #5069
    Jul 2017
    The message was deleted.
  17. #5070
    May 2017
    Can you explaine me more ? WHat i must do ? Remove this capacitor ?
    Soft is here on zippyshare
    http://www69.zippyshare.com/v/8F7atkRJ/file.html
  18. The Following User Says Thank You to pepeEL For This Useful Post:
    BASi77 (21st July, 2017)
