Page 362 of 854 FirstFirst ... 262312352357358359360361362363364365366367372412462 ... LastLast
Results 5,416 to 5,430 of 12803
  1. #5416
    Feb 2017
    Christmas present for everyone. New loader V3 working with 17.8.1 (thx to magadan).
    It is necessary to modify the EEPROM. Either by programmer or by VAGCOM_EEWrite if previous version of the loader was used.
    Enjoy
    ... Kolimer ...
    Edited:
    Unpublished the loader because it is not 100%. Stay tuned.
  2. The Following 17 Users Say Thank You to kolimer For This Useful Post:
    alexm1 (30th December, 2017), BWF (29th December, 2017), H2Deetoo (30th December, 2017), hartklep (30th December, 2017), hid3 (29th December, 2017), ivica21 (30th December, 2017), jakuza (3rd January, 2018), jokir (30th December, 2017), Mario6 (30th December, 2017), mattock808 (29th December, 2017), Pma54 (5th February, 2018), sania387 (30th December, 2017), SDfgdhfj (29th December, 2017), tr3ce13 (30th December, 2017), vaicekas (30th December, 2017), Wene001 (29th December, 2017), xoom (30th December, 2017)
  3. #5417
    xoom's Avatar
    Dec 2009
    Ylakiai
    False alarm
  4. #5418
    Aug 2009
    Quote Originally Posted by xoom View Post
    False alarm
    About what?
  5. #5419
    xoom's Avatar
    Dec 2009
    Ylakiai
    too much versions compared same files )
  6. #5420
    xoom's Avatar
    Dec 2009
    Ylakiai
    Still looks not right...
  7. #5421
    Jul 2016
    Vilnius
    Kolimer, others,
    I confirm that the V3 stuff ant 17.8.1 DOES NOT WORK CORRECTLY.
    Checked on a car with CAN/UDS protocols.
    I wouldn't suggest anyone use it at this stage.
    I can calculate ABS module codings for:
    * Continental/Teves MK60EC1 and MK60;
    * TRW systems in Passat B6 / B7 / CC /Tiguan;
    * MK100
    * Bosch ABS8.2, ABS9.0 and ESP8.2, ESP9.0;
    * EBC 460 (UP!, Mii, Rapid, CitiGo, Fabia, Toledo, etc) New!
    ... and other VW/Audi/Seat/Skoda modules.I can assist with repairing \/CDS interfaces.
  8. #5422
    May 2010
    Quote Originally Posted by kolimer View Post
    Vagcom_EEWrite is the same like previous or new version too?
  9. #5423
    xoom's Avatar
    Dec 2009
    Ylakiai
    There is different eeprom content:
  10. #5424
    Feb 2017
    I can confirm that adaptation channel items are shifted by one in version 17.8.0 and up. Anybody to compare with genuine interface?
  11. #5425
    Oct 2014
    Netherlands
    First of all thanks kolimer and magadan for releasing this!
    I just tested with my clone 0x46 interface and I can see the same behaviour: atleast some channels are shifted by 1.
  12. #5426
    Jun 2010
    The problem of long coding is solved?
    What is the problem with V3?
  13. #5427
    Jul 2016
    Vilnius
    Quote Originally Posted by BWF View Post
    Issue is described here:
    http://www.digital-kaos.co.uk/forums...=1#post3126190
    and here:
    http://www.digital-kaos.co.uk/forums...=1#post3135230
    Originally in the posts it refers to V2 but V3 has got the same issues.
    * MK100
  14. The Following User Says Thank You to hid3 For This Useful Post:
    BWF (30th December, 2017)
  15. #5428
    Jan 2009
    tomorrow i have eventually the chance to test a genuine Hardware with adaption channel issue, so we can be sure the problem doesnt exist with genuine hardware.
    I´m a VCDS Newbie.
    Can someone explain what to test in detail?
  16. #5429
    Jan 2010
    Trstenik - Thun
    Default VAG-COM/VCDS EVERYTHING
    @Kolimer
    Sorry for my question but what exactly are differences between V2 and V3?
  17. #5430
    Jan 2009
    The Diode on 16 pin is good for 2x2 adapter.. you can easy mix + and - becouse those adapters are like rubber and you can plug it wrong way..
    Aah thanks, that makes sense to have a reverse polarity protection....
