Hi, did someone sew such a model of a lace? Now the firmware is 12.12. I want to update to 17.8.1.
the pictures are too small te idfentify the components .
verify if the processor is an atmega 162 , and if the gal is present .
then control the tracks from processor to gal to see which version you have.
all info is in kolimers zip file on this forum.
hi, where can I find kolimer (v6.3 loader )?
I sent you the activated licence, check your PMs
So does
- Loader:
http://ge.tt/7zLlAZo2
https://www.sendspace.com/file/1k82p4
and
have Virus in them? Windows 10 seems to think they includes
Trojan:Win32/Bitrep.A Virus, Uninstall Trojan:Win32/Bitrep.A
What Is Trojan:Win32/Bitrep.A
Trojan:Win32/Bitrep.A is a highly malicious auto-exutable Trojan virus created by vicious cyber criminals. With the ability to install itself automatically in compromised PC it is very hard to detect or remove this notorious infection. It usually sneak in targeted computer by stealth and quickly disable all you security measures in order to hide itself easily in compromised computer. According to cyber security experts, Trojan:Win32/Bitrep.A is a very harmful PC threat which belongs to Trojan horse category. It mostly targets Windows OS based computers. It is such a risky threat which connect your system with remote server and allows the hackers to access your entire PC remotely.
So is it safe?
Hello
I've been reading this topic for some time, but I've had a break for several years. We used to have a similar thread in another forum, but when there was too much information there, the whole topic was deleted. I return to the analysis of the program and I am looking for people with RE experience in order to exchange information. I finished the analysis of program on generating serial and assigning it to FT, but I miss the RSA private key. If anyone wants to share knowledge about RSA, I will reciprocate the same.
Hello for 18.7 kolimer loader work?? Or only chins 1.2 loader ? Thks
If you have original V2 or NET hardware, you can test the loader but it will not have atmega162 chip.
Hello guys. I have flashed about 10 VCDS (15.7 RED PCB, 12.12 GREEN and 17.0, 17.8) with kolimers v4 and v5 loader, everything was fine. But now i am stuck. I don't know why but last 3 VCDS clone 17.8.1 i cant reflash with USBasp - when i first time conected i can read chip, i add PROJECT from v5 and PRESS AUTO. Atmega starting programming but after about 10 s i geting error (somthing about can't verify flash or...), and i am try second time with project from v4 - this same problem. After 3-4 times programming i getting another ERROR - CANT ENABLE CHIP. And no more cant read ATMEGA. I have 3 same interfaces now with same problem.
szurke (25th July, 2018)
Your pics are not clear, try to atach again at full resolution
Try again with usbasp, check again mosi miso sck reset conection, power 12v via obd2 ,ground to usbasp too.
Use 0x44 dump.
please someone activate this loader chinese ver 1.12 18.2 english version
