Page 450 of 854 FirstFirst ... 350400440445446447448449450451452453454455460500550 ... LastLast
Results 6,736 to 6,750 of 12803
  1. #6736
    May 2010
    Tried viceversa too?
    Move components from bad to good and see if good remain good?
    You changed "important components", i undestand CAN 2 pcs ICs, Atmega, Qtz, maybe GAL...
    But the same issue can be generated by a "passive" component like resistor, capacitor OR...PCB? Or soldered wires? etc...
  2. The Following User Says Thank You to liviudiaconu For This Useful Post:
    makadam (6th September, 2018)
  3. #6737
    xoom's Avatar
    Dec 2009
    Ylakiai
    Try measure voltages first on CAN Lines:
    CAN_H - GND = 2.5v
    CAN_L - GND = 2.5v
    measure resistance between CAN Lines(not powered cable):
    CAN_H - CAN_L= 120ohm
  4. The Following 2 Users Say Thank You to xoom For This Useful Post:
    makadam (6th September, 2018), seal777 (8th April, 2021)
  5. #6738
    Feb 2018
    Latvia
    Hi friends. Maybe someone knows what is this capacitor? It is broken and I want to know witch capacitor to buy.
  6. #6739
    Newbie adicristi's Avatar
    Oct 2017
    Europe
    Is ok to order a vcds from obd2cartool?
    I found a HQ vcds that support Long codding.
    V16.8
    Sent from my Mi A1 using Tapatalk
  7. #6740
    Oct 2017
    Germany
    Quote Originally Posted by kashelis View Post
    Use 12 µF SMD capacitor.
  8. The Following 2 Users Say Thank You to networkers For This Useful Post:
    kashelis (6th September, 2018), seal777 (8th April, 2021)
  9. #6741
    Oct 2017
    Germany
    Quote Originally Posted by adicristi View Post
    I found a HQ vcds that support Long codding.V16.8
    Yes you can buy this 16.8 "Do it yourself" Interface with programming pins (Model: OBD649) and reflash. You need an USBasp programmer.
    Or use it with the supplied 16.8 crack Software.
  10. The Following User Says Thank You to networkers For This Useful Post:
    belkor (6th September, 2018)
  11. #6742
    Feb 2018
    Latvia
    Thank you
  12. #6743
    Feb 2018
    Latvia
    Quote Originally Posted by networkers View Post
    But how much volts?
  13. #6744
    Jul 2018
    Quote Originally Posted by makadam View Post
    Different cars and every car was was after 2010 y. Problem is strange because I change almost every important component from working cable to non working but never succeeded to repair them! I have both version 0x44 and 0x46. I try several times connect disconnect check can-H can-L connection but nothing. I noticed that also some people have this problem but no one found solution. Once time even I bought 2 pcs chinese cables (red one) with this problem it was 15.7 version, one ot them has this problem!
    I had the same problem. I returned version 17.8.0 VCDS loader V5 and now all worked .
  14. The Following User Says Thank You to shkumbata74 For This Useful Post:
    makadam (11th September, 2018)
  15. #6745
    Oct 2017
    Germany
    But how much volts?
    Between 6-10V should be ok.
  16. #6746
    yellowstilo's Avatar
    Nov 2009
    try 100 nF - it's not critical because it's between power supply and ground…..
  17. The Following User Says Thank You to yellowstilo For This Useful Post:
    belkor (8th September, 2018)
  18. #6747
    Nov 2009
    Maybe somebody could point me in the right direction with the folowing:
    I have a HW 44 cable with stc chip (now removed), the same as found on page 3 in the guide that comes with kolimer packages. (Hardware Type HW 0x44Identification : ATMega pins 34 and 35 must be connected to GAL chip.)
    Have tried to use the VAGCOM_EEWrite methode but didnt work, so i read almost this complete thread and comprehended that i also needed to cut the STS cip on line 9.
    Tried to do this but it failed and i removed the chip in completely.
    Question> Do i need to remove also a few other transistors/resistors as stated in this forum? Wich ones because for an example R51 isnt there only R50. Anyone familiar with this board?
    When connected to VCDS or VAGCOM_EEWrite.exe i get a no connection error. VCDS does recognice the cable like it is now but it says it's not connected to the car even though it is.
    Do i need to flash it with a usb tool? With one can i order best?
    Here is my board with the ptc already removed...
  19. #6748
    Feb 2014
    where you removed STS chip try to clean better .....seems to make contact and try:
    plug in your cable into OBD socket
    open MProg3.5 ...click Device -- Scan.....Number of programmed devices=1.....Tools -- Read and Parse......File --Save(save backup)......File --Open and load ftdi_mprog_BMBL.ept.......Device -- Program
  20. #6749
    Jul 2016
    Vilnius
    Remove the excess solder.
    R50 must stay in place.
    I can calculate ABS module codings for:
    * Continental/Teves MK60EC1 and MK60;
    * TRW systems in Passat B6 / B7 / CC /Tiguan;
    * MK100
    * Bosch ABS8.2, ABS9.0 and ESP8.2, ESP9.0;
    * EBC 460 (UP!, Mii, Rapid, CitiGo, Fabia, Toledo, etc) New!
    ... and other VW/Audi/Seat/Skoda modules.I can assist with repairing \/CDS interfaces.
  21. #6750
    Nov 2009
    Thanks @hid3 and belkor. Done now. So to flashing of chips is required? all can be done trough the USB cable?
  22. The Following User Says Thank You to Erikol For This Useful Post:
    belkor (9th September, 2018)
