Usually is dead when you get malfuntion device or no device detected in dev manager; or is seen from time to time...
On the pcb there is fake ftdi without any description. Interface is 4 mount older its working with colimer 6.3 after flash with usbasp.
I will try another Computer and see if it stil unknow devise.
VAGCOM_EEWriter.exe (quoted into file "Info.pdf") IS NOT in VCDSLoader_v6.3.zip file...
Any sugestion? Thank you.
Yes, that file was in V5 and older versions.
Use VAGCOM_EEWriteLang.exe for the same purpose.
This cable is on atmega and could be repaired with USBasp?
Not Atmega inside.
1 6 D (3rd October, 2018)
Hi Guys,
First of all I'm using and old-fashioned, but goot HEX-CAN with AT162 and it works well for me... Today I got a few pics about a cable and I'm very interested your opinion. As the owner (seller) told me it can update itself online, it supports 16 langs in the same time and it needs a Loader (v1.12e) too.
I know nobody love and believe in online uptadeable cables, but pls take a look and tell something about it.
ok, tell what?
Connect obd side to 12v source, connect to usb port, try to flash it with v6.3 eewritelang. If bootloader is locked use a programmer solution.
Ask seller can it run multiple vcds executables in the same time and read engine ecu with english, abs with polish and gearbox with chinese... Can it?
Don't see real purpose with 16 languages in the same time.
That cable is like a "V6.1 ?? cable" but bad copy. Because V6.1 clone have another power regulator. This have a 78L05... If the quality still the same as at first "6.1" cables, is ok. little components. If this, is possible 78L05 be still cold.
v1.12e loader..i don't know. A chinese petard? with registration?
Tib82,
this one is (was) a genuine RT but with blacklisted serial or very similar to it. Chinese bought these cables in order to reverse engineer and make clones.
Good/quality piece of hardware, works fine with Kolimer's stuff once reflashed.
I can calculate ABS module codings for:
* Continental/Teves MK60EC1 and MK60;
* TRW systems in Passat B6 / B7 / CC /Tiguan;
* MK100;
* Bosch ABS8.2, ABS9.0 and ESP8.2, ESP9.0;
* EBC 460 (UP!, Mii, Rapid, CitiGo, Fabia, Toledo, etc) New!
* ... and other VW/Audi/Seat/Skoda modules.I can assist with repairing \/CDS interfaces.
The default language is English and most of the Earthlings can use it more or less. But what if I wanna use 2 other languages in the same time? The cause is not important... Beleave it or not, it has prupose. For me or for somebody... but has... But okay, forget the number of langs for a while....
I think the most important part of this question, is there any chance that it can update itself online to the latest release without blocking?
And if any problem appears, there is a possibility to re-flash it.
If it is truly a re-flashable cable (and not a cheap clone) and if is hasn't got any serious issue, than it knows more than a "usual HEX-CAN" interface (online update and multi lang support). In this case why not this one is the most used version?
This is what I found how the Loader Eva v1.xx looks like:
https://www.linkedin.com/pulse/how-i...are-steven-hou
Does loader 6.3 work properly with VCDS 18.2.1 russian language?
Is there any way to edit the *.CLB files to add my own descriptions ?
Thx
Meat-Head (4th October, 2018)
