Some progress, made - developed Arduino Mega based bruteforce interface with GAL slot and tested with GAL from working 0x44 cable, chip works fine after such manipulations
Wrote simple program to toggle each pin and check remaining pins state:
TODO: implement code for each combination toggle; Karnaugh map minimizer for logic generation.Code:void setup() { Serial.begin(115200); //Main loop for(int i = 22; i<=39; i++){ //Pin configuration loop for(int j = 22; j<=39; j++){ if(i == j){ //Set togg'able pin as output pinMode(j, OUTPUT); }else{ //All other pins as input (high impedance) pinMode(j, INPUT); } } //Toggle output high digitalWrite(i, HIGH); for(int j = 22; j<=39; j++){ //Skip checking togg'able pin from reading if(j == i) continue; //Check if input is high if(digitalRead(j) == HIGH){ //Print values to UART Serial.print(i); Serial.print(" "); Serial.println(j); } } //Toggle pin back digitalWrite(i, LOW); } }
Results:
OUTPUT PIN 1-(10 skipped, GND)-19 INPUT PIN 1-(10 skipped, GND)-19 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 - 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 - 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 - 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 - 1 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 - 1 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 - 1 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 - 1 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 - 1 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 - 1 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 - 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 - 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 - 1 1 1 1 1 1 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 - 1 1 1 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 - 1 1 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 - 1 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 - 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 - 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 -
As it seems things get tricky, as it seems from datasheet, GAL can be configured as clocked, and registered modes:
So for further investigation I need someone who can tell about known 0x44 configuration (additionally to C3H8 logic), as well as create .JED file with known logic to check if bruteforcer works fine.
Cheers![]()
The algorithm of work and programming CUPL of FPGA is well described in this article. https://justmoose.ru/?p=17
LaiquePlease read the info file in the colimer folder, as well as several pages of the forum and you will find the answers.
Please read the info file in the kolimer folder, as well as several pages of the forum and you will find the answers.
Hello @LL,
can someone reupload the newest loader for \/CDS 18.9.0 (DRV) German and the firmware files please ?
Thank you in advance.
Best regards
schmiddie1982
Gesendet von meinem F8331 mit Tapatalk
Run VAGCOM_HWType.exe to see if you have locked bootloader, then VAGCOM_EEWriteLang.exe if it's not locked and you don't know how old vcds version was used for it, use loader, and then update firmware after port test.
Check last post from Kolimer, there are still some loader links active.
schmiddie1982 (30th December, 2018)
thx. for the answear man!
This is all what VAGCOM_HWType.exe is telling me. How do i know if the bootloader is locked ? The cable works with 17.1.3 now.
That exe is not from 7.2 loader.
Anyway you can try eewrite and it will tell if it's not in bootloader mode or flash it succesfully.
Don't forget to plug it in obd2 port while flashing.
Latest not very, but you can report your findings in this topic.
Hi, is possible to repair this cable?
Yes, you can. But first you need "kill" STC, see how in info.pdf from Kolimer zip.
L.e.
You may need to use usbasp programmer, I do not think will work by usb, but you can try...
About your schematic i don't see K-line and L-line Rx. K-line and L-line are bidirectional.
If that transistor with emiter "in air" i assimilate as a diode, can be Rx. And go on 17 and 19 pins of GAL. Thet mean that pins are IN, not OUT.
Look as a correct schematic for a 44HW, not transistors but correct and can see the Rx (K/L lines)
Got the 18.2.0!!! It's ALIVE!
@KOLIMER! WHEREVER YOU ARE, GOD BLESS YOU.
Small tribute for you man!
