Page 530 of 854 FirstFirst ... 30430480520525526527528529530531532533534535540580630 ... LastLast
Results 7,936 to 7,950 of 12803
  1. #7936
    Jul 2016
    Vilnius
    Why doesn't everyone read the document inside the pack? It has got ALL the information covered there
    I can calculate ABS module codings for:
    * Continental/Teves MK60EC1 and MK60;
    * TRW systems in Passat B6 / B7 / CC /Tiguan;
    * MK100
    * Bosch ABS8.2, ABS9.0 and ESP8.2, ESP9.0;
    * EBC 460 (UP!, Mii, Rapid, CitiGo, Fabia, Toledo, etc) New!
    ... and other VW/Audi/Seat/Skoda modules.I can assist with repairing \/CDS interfaces.
  2. The Following 3 Users Say Thank You to hid3 For This Useful Post:
    jan4 (8th March, 2019), litllevill (8th March, 2019), Mario6 (9th March, 2019)
  3. #7937
    Feb 2013
    UK Bristol
    Quote Originally Posted by vzinic View Post
    do I need remove this chip for update?
    Attachment 602164
    Thanks and BR
    No. This is fdti chip. Update throught usb? Or you mean Flash atmega? Anyway ftdi stay there.
    My post helps you? Please Hit Buttons
  4. The Following User Says Thank You to pocinas For This Useful Post:
    vzinic (8th March, 2019)
  5. #7938
    Jul 2017
    Default MQB 2019+
    Is K-Line used in MQB 2019+ models or CAN only?
  6. #7939
    Feb 2019
    I think communication only takes place on CAN in MQB 2019+ cars models!
    I think communication only takes place on CAN in MQB 2019+ models
  7. #7940
    May 2010
    Thanks and BR
    Hid3 said very well; read the document attached in archive.
    And yes, this is the chip recomended to be desoldered. Not mandatory, is sufficient to cut the copper line like in document. But i RECOMMEND to desolder that chip if is possible. And that second reseter too. Like in photo
  8. The Following 3 Users Say Thank You to liviudiaconu For This Useful Post:
    kaalis (8th March, 2019), litllevill (8th March, 2019), Mario6 (9th March, 2019)
  9. #7941
    Sep 2016
    Hello All i got Vcds need to be Fixed but it's without Atmega chip but i manage to buy it on line only the ship atmega 162 Can i replace it with the ohter chip in my vcds ??
  10. #7942
    Jul 2016
    Vilnius
    Mate, you just wasted your money twice. The pinouts between NEC and ATmega162 are different
    * MK100
  11. #7943
    Feb 2019
    Quote Originally Posted by heshamzn View Post
    Example of good interface:
    http://www.obd2cartool.com/vagcom-16...version-p-1266
    http://www.obd2cartool.com/atmega-va...hipping-p-1554
  12. #7944
    May 2018
    Quote Originally Posted by hid3 View Post
    Hid3 i sent you a PM about MY2019 patch
    please, see when you have time
  13. #7945
    Feb 2019
    Hey guys.
    I've recieved today VCDS "HEX-V2" from AliExpress but I have a weird issue..
    Device cannot be connected to PC with cable longer than 40cm.. yeah that's weird..
    Used cable which came with device and it shows as "Ross-Tech HEX or KEY USB Interface" but with error in Device Manager "This device cannot start (Code 10)" or as Unknown USB Device (Device Descriptor Request Failed)..
    Tried different USB cables (longer than 40cm) and still nothing..
    but short cable (about 40cm which I've got with arduino clone) = no problem, also succefuly flashed 1.96 flash without any problems (detected as 0x46 with Bootloader Enabled), connected to vehicle (definietly cable is too short for normal usage) without any issues.
    Anyone got idea what is going on?
  14. #7946
    Mar 2018
    Quote Originally Posted by meciu View Post
    Hey guys.
    Hi, it's not about the cable, but about the wrong driver. You have a 0x44 PCB
  15. #7947
    Feb 2019
    Allright, then where I can get good - working drivers?
  16. #7948
    Mar 2018
    Do trader shit with Ali)
    Put TV help, it's free, do not be afraid)
    Although your cable may be consuming a lot of milliamperes, turn off power savings laptop
    Although there may be poor contact of the cable and the port of the laptop or adapter.
    Check the cable on Arduino)
  17. The Following User Says Thank You to Roma77 For This Useful Post:
    meciu (14th March, 2019)
  18. #7949
    Feb 2019
    Quote Originally Posted by Roma77 View Post
    ok, dispute opened with trader.
    Contact between laptop and device is perfect, even with cable from vcds - arduino and midi controller works without any issues.
    So device itself or firmware or drivers are bad.. but still I don't understand why vcds works with shorter cable
  19. #7950
    Jul 2018
    Will Vag Tacho 5.0 can find Pin Codes for this models:
    Golf MK6 2012
    Seat Leon 2008
    Thanks.
