Page 553 of 854 FirstFirst ... 53453503543548549550551552553554555556557558563603653 ... LastLast
Results 8,281 to 8,295 of 12803
  1. #8281
    May 2019
    I installed VCDS 18.9 from Ross, and i used VCDS loader from this site, now When is Ok "Can" when is not ok. If i take a test and Can is OK and i want to do an Autoscan to my car give me this message "Function not supported by the gateway"...gateway.JPGok.JPG
    BTW... I still have an old interface which was 11.2, and a guy upgrade to 15.5 two years ago and is still working very good, but i want to make update to 18.9...Is possible to have the same experience with interface from China?
    Thank you so much
  2. #8282
    Mar 2018
    Quote Originally Posted by bogdanbgd View Post
    Thank you so much
    Try removing tick from UDS agressive mode.
  3. #8283
    May 2019
    hi all,
    I just wanted to thank everyone involved in getting all these tools and cables working.
    before I found this forum I bought this cable, which I now realise I paid waaaay too much, but anyway...
    http://www.obd2cartool.com/vagcom-18...anguage-p-1263
    The supplied CD was DOA so I had no instructions and no compatible VCDS version to install. With the tools, links and info on here I was able to reflash the cable and get VCDS 18.9.1r1 up and running. It even works with my 5F Leon (2013) which is an MQB and not supposed to work
    all just to re-code an upgraded battery
    in any case, I figured I would post my results for anyone else who might have the same cable/problems.
  4. #8284
    Member lemta's Avatar
    Jun 2012
    Quote Originally Posted by hid3 View Post
    Hello dear DK members and VAG lovers,
    just wanted to let everyone know that OBD2CarTool shop really cares about us and now they have become even better!
    Besides the fact that they offer VIP price for interfaces for us, they also started offering a possibility to order USBASP programmer - so now you can get all the required stuff in once package with quick delivery! Personally I think it's the best deal you can ever get.
    Here's the link: https://www.obd2cartool.com/vip-link...86o4so84i9m7r7
    Pay attention there are two Packages - Classic and "HEX-V2" interfaces as well there are two options - with USBASP programmer or without it.
    Enjoy!
    "* Comes with no specific EEPROM (must write on your own)"
    "...cable with Bootloader"
    What do these 2 lines mean in the advert? Can you program/update the cable through USB without the USBISP?
  5. #8285
    Jul 2016
    Vilnius
    Quote Originally Posted by lemta View Post
    1st line - some EEPROM is flashed but hell knows which. It should not be expected to be valid out of the box;
    2nd line - bootloader enabled.
    Yes, you can reprogram this cable via USB without the USBISP
    I can calculate ABS module codings for:
    * Continental/Teves MK60EC1 and MK60;
    * TRW systems in Passat B6 / B7 / CC /Tiguan;
    * MK100
    * Bosch ABS8.2, ABS9.0 and ESP8.2, ESP9.0;
    * EBC 460 (UP!, Mii, Rapid, CitiGo, Fabia, Toledo, etc) New!
    ... and other VW/Audi/Seat/Skoda modules.I can assist with repairing \/CDS interfaces.
  6. The Following User Says Thank You to hid3 For This Useful Post:
    lemta (17th May, 2019)
  7. #8286
    May 2019
    Could helps someone with vcds 18.9.0 in English? Because i made an update to my second interface and has the same problem. I can't made a test to my car.... Thank you so much
  8. #8287
    Feb 2019
    RUSSIA
    Hello dears! Here I read here smart people and bought "the only correct cable" on a special link for members of digital-kaos on obd2cartool, option hex+can. The goods came all the same from China. Scheme 44 HW when contact 34 and 35 pins of the Atmega on the GAL chip, but the firmware of the cable 0x46 HW! Had to alter under 44 HW... Where's the quality? Or am I missing something?
  9. #8288
    May 2019
    Hi everyone.
    I have a Seat Ibiza (KJ1 - 2018 - MQB Platform) what cable do i need?
    If i understand correctly, a clone of hex-v2 should be sufficient, right? what are the differences between hex-can and hex-v2?
    For example, this will work?
    https://www.obd2cartool.com/atmega-v...gh1jgm4016dpr2
  10. #8289
    Mar 2018
    Quote Originally Posted by RiHard View Post
    missing something!
    Reduce the tone and maybe you will answer.
    To get the right answer, you do not need to write ironic posts with questions posed in this style.
  11. #8290
    Feb 2019
    RUSSIA
    Sorry if You saw the sarcasm and bad form, did not mean to offend. But over the last hundred pages, the red thread is the idea that obd2cartool has good cables. And what I got from this store, in my view, does not correspond to HW. Where is the error?
  12. #8291
    Mar 2018
    The fact that you have not given anything gives, there is also ATF / GAL 0x44 0x46 firmware and a hybrid, they control the atmega contacts.
    Everything works on both version 0x46 and 0x44.
    Therefore, here you can find a post where it is written that a scanner without logic is like a man, but without eggs.
  13. #8292
    Feb 2019
    RUSSIA
    Could not correctly get the translation of the answer, please write in other words. In the meantime, as I understand it, the cables from Obd2cartool some special combination of chips that can work with 44 and 46 HW? I just have a fact, a case where this 44 HW chip set killed the BCM by replacing the Bytes. If anything, I got from the shop inside the cable like in this post https://www.digital-kaos.co.uk/forum...=1#post3565634
  14. #8293
    Mar 2018
    Could not correctly get the translation of the answer, please write in other words. In the meantime, as I understand it, the cables from Obd2cartool some special combination of chips that can work with 44 and 46 HW? I just have a fact, a case where this 44 HW chip set killed the BCM by replacing the Bytes. If anything, I got from the shop inside the cable like in this post https://www.digital-kaos.co.uk/forum...=1#post3577107
    I know what you are writing about, I read your blog)).
    This scanner does not add zeros to the encoding in whatever version it is).
    С этим сканером нет смещение кодировок и затирание ееprom.
  15. #8294
    Feb 2019
    RUSSIA
    Sorry, error message
  16. #8295
    Jan 2010
    Trstenik - Thun
    Quote Originally Posted by CappyT View Post
    Hi everyone.
    Of course it will not work!
    HEX-V2 is ONLY original, clone doesn't exist yet.
    obd2cartool SELLING crap old clone of HEX-CAN interface, in the housing simmilar as original hex-v2,and that is THE ONLY similarity with Original HEX-V2.
    This Clone can not work with new UDS protocol and can not do long coding to BCM as well....and can't do many other things
    Sent from my HONOR 8X
