mattock808
Here you have.
CZ
EN
PL
https://zachowajto.pl/hledej?q=vcds+...tocomplete=std
mattock808 (24th July, 2019)
Any ideea how this situation is possible? VCDS doesn't detect the interface, but HWType does:
18.9.0 CZ is latest ?
Hi.
I'm trying to fix my old chinese cable with Atmega chip.
I've flashed it using programmator and VAGCOM_EEWriteLang.
Everything seems ok, cable passes test, connects to car (Golf 7 2013).
But when I try to write a new value (for ex. Adaptation...DimmwertAB 25) i get error:
"This interface does not support sending CAN messages 256 bytes and over in length"
I've tried different VCDS version from 17.1 (it was on disc with the cable) to 19.6.0, different Loaders versions from 5 to 8, different firmwares...
But no luck, I'm still getting this error.
The cable worked well a few years ago with the same car. I was able to write values (for ex. in Adaptation...DimmwertAB 25).
Can't get what I'm doing wrong.
What else to try?
Thank you.
Update:
Just figured out what was wrong. I tried to edit the wrong channel. "...Light configuration..." instead of "...Leuchte25KZL HA59...".
Ughhh...
First of all, remove those two jumpers.
Secondly, you have flashed it as HW 0x44, right?
I can calculate ABS module codings for:
* Continental/Teves MK60EC1 and MK60;
* TRW systems in Passat B6 / B7 / CC /Tiguan;
* MK100;
* Bosch ABS8.2, ABS9.0 and ESP8.2, ESP9.0;
* EBC 460 (UP!, Mii, Rapid, CitiGo, Fabia, Toledo, etc) New!
* ... and other VW/Audi/Seat/Skoda modules.I can assist with repairing \/CDS interfaces.
Hi.
I've done all this (flashing and connecting to car) with those two jumpers and without them.
Also I've tried flashing both firmwares 0x44 and 0x46. Cause I'm no sure which revision it is. Pin 35 is connected to GAL, but pin 34 is not.
It works the same way. VCDS test says OK. I can read values from car but cannot modify.
Licence is activated on VCDS ?
hi please need dump for 2 models of vcds 0x44 and 0x46
thnks a lot
Hi everyone. I have a HEX-V2 clone cable. With version 18.9 it works. I installed version 19.6 of kolimer but it doesn't work. The Failed 4 message always comes out. What can I do? Thank you
You should do, what everybody does...wait for a new fix and until that, use 18.9.0.
Nicolar (25th July, 2019)
The problem is that the program does not work. When I open it from the loader.exe it gives me Failed 4. Without that I connect the cable to the computer. Then the loader.exe does not work? Thank you
While awaiting for the fix, grab current release, as later they will silently "replace" the installer![]()
* MK100;
