French version (FRM) too
How to fix k2 short to ground, i havent used the cable like 5 times. I get this on two cars. Hex v1
Component in blue next to D3
Does someone know the name of burned SMD component?
It's the V2 ( V1 Atmega kolimer)
I would guess it is a SMD diode, same as D2. Maybe a 24V Zener-Diode?
Its written 24
When I test the good one, in diode mode in one direction reading : 1380, in other way 820
Wen I test in resistance ( 2000 ohm) I get 1510; in other 1430 in other direction.
look at this , maybe you are lucky
http://www.s-manuals.com/pdf/datashe...4-zd36_utc.pdf
maybe another forum member knows this component
So basically I need a Zener diode 0.5W 24V SMD ?
I know that the one diode is working, i supose its for K1, K1 works. K2 is dead. But I dont know what value of diode to get.
And it seems by looking from past posts that they are using lower quality components than in past.
I think the part is :
PDZ3.6B
90% its
Mega.nz VCDS Hex-V2 VIIPlusLoader-08.021.05 link
1. Support V21.3.0
2. VIIPlusLoader support multi-languages
https://mega.nz/file/05M2iTpZ#TI537M...u7H5n22LjOjE7g
adrianoo (4th March, 2021), AYD (4th March, 2021), badrax (4th March, 2021), bnfghmjkljkhiu (4th March, 2021), Col19 (4th March, 2021), GJ1949 (4th March, 2021), goveng (4th March, 2021), Goze91 (7th March, 2021), isavrseno (8th March, 2021), jakuza (19th March, 2021), jan4 (4th March, 2021), kaalis (4th March, 2021), liviudiaconu (4th March, 2021), Mario6 (4th March, 2021), miouser (4th March, 2021), Nullos007 (4th March, 2021), peetr (4th March, 2021), Raimax (4th March, 2021), seal777 (4th March, 2021), teddy11 (8th March, 2021), Tomas005 (4th March, 2021), ZIPPO4594 (4th March, 2021)
