Page 771 of 854 FirstFirst ... 271671721761766767768769770771772773774775776781821 ... LastLast
Results 11,551 to 11,565 of 12803
  1. #11551
    Mar 2009
    Quote Originally Posted by Gimse View Post
    Yes, i confirm that there are code security access issues in English. If you use another language 21.9 with loader 08.22.05 everything is ok. Yesterday, 22.3.1 appeared in the other languages but I didn't have time to test to see if there are the same problems.
    ENGLISH 21.9 WITH 08.22.05 works fine for me
  2. The Following 2 Users Say Thank You to subzdarg For This Useful Post:
    dynamic20 (20th September, 2022), garyr (17th June, 2022)
  3. #11552
    ASCM's Avatar
    Oct 2018
    Quote Originally Posted by alexm1 View Post
    anyone can help with Interface programming pinout ? For connecting to Uspasp prog.
    Mosi, MISO. SCK RESET.
    Pic below.
    L.E. - this is hex V2.
    i have the same cable as yours how did flashed i have upa 1.3 can you help to repair?
  4. The Following User Says Thank You to ASCM For This Useful Post:
    seal777 (8th June, 2022)
  5. #11553
    May 2010
    EU
    Quote Originally Posted by ASCM View Post
    That's fake Hex-v2.
    UPA adapter #1 pinout look in uuprog.pdf in your software.
    https://imgur.com/WBxWIXKhttps://imgur.com/WBxWIXK
  6. #11554
    Jun 2022
    Does anyone have vcds lite and loader
  7. #11555
    Top Poster jan4's Avatar
    May 2018
    somewhere in Belgium
    more than 10 years old .......
  8. #11556
    Feb 2017
    Poland
    Dear, what is the latest loader that works with VCDS v1 Amtega162 chip? Is it the one mentioned below? What is the latest VCDS it works with?
    https://www.digital-kaos.co.uk/forum...06#post3639906
  9. #11557
    Aug 2018
    France
    @ireun :
    yes, the lastest loader for hex-can (Atmega162 chip based) is 9.2 by Kolimer
    edit :
    Vcds 22.3.1 FRM available
  10. #11558
    Jun 2022
    IMG_1328.jpgIMG_1329.jpgIMG_1329.jpgIMG_1327.jpghello
    i have vcds 21.9 kolimer loader v9.2 hex v2 atmega 162 2117E17 FTDI FT232RQ
    the problem started after a recent connection to the vehicle.
    when the laptop was connected it blocked and since then I can't connect to any module on the car
    the interface blinks green when connected to the car I run vcds I click select and then the modules that have any on the car to click just a little as an attempt to open and nothing happens I can not access any module
    I tried to reinstall the driver by deleting and the installation failed I deleted the entire program from the laptop reinstalled failed again
    as far as i know this is a clon version not orginal ross tech
    after that i get help from Mario6 to take look on this post and download all i need but after i use vag com hw type to see is bootloader enabled and yes it is
    then i use vcds usb eeprom write english language selected and finished that
    i start vcds whit interface and he ask me to update offline
    after finished update
    i do test and try to enter module on car
    and her are pictures of all proceses what i do
    this time he entered module on car but after few secunds give me a messege no response from controller!
    i tried change of version of vcds tried whit difrent drivers loaders but no use
    can sombady help me i dont know what next to do
  11. #11559
    Feb 2018
    VCDS 9.2 by Kolimer it's not working on latest 22.3.1 (Hooking failed) and 21.9 cannot be installed anymore because "software is too old, please update to latest version" or something similar. Last working version is 21.3
  12. The Following User Says Thank You to thunderbolt96 For This Useful Post:
    rtbdiagnostic (15th June, 2022)
  13. #11560
    Jun 2022
    Anyone
  14. #11561
    Dec 2014
    PL
    Quote Originally Posted by thunderbolt96 View Post
    For me, the Kolimer loader 9.2 works fine. I checked on VCD$ 22.3.1EN and VCD$ 22.3.1AKP.
    (old VW Passat B5 and B6)
    But the SEAT ATECA 2019- "message -vehicle not supported".Buy or replace the interface with HexV2 or something like that.
  15. The Following 2 Users Say Thank You to Mario6 For This Useful Post:
    jakuza (16th June, 2022), rtbdiagnostic (15th June, 2022)
  16. #11562
    Feb 2018
    Quote Originally Posted by Mario6 View Post
    I've tested it on VCDS ITT and i got the Hooking failed error.
  17. #11563
    Feb 2022
    @badrax
    "Does anyone know where I can get the Hex-V2 STM32F415 from outside of AliExpress?
    This type of interface. (NOT the 405 VIIPlus crap)"
    Hi!
    Late, but in case you have not find any.
    https://www.obd2cartool.com/index.ph...oducts_id=1211
    And thank you all for the great work you put in this!
    My best Regards
  18. The Following User Says Thank You to Tor999 For This Useful Post:
    badrax (4th November, 2022)
  19. #11564
    Jun 2022
    Default Vcds HEX 2 not working
    Brought a hex 2 clone, but I can't seem to get it working.
    STM92F429
    VET 6
    9909Y 9R
    MYS 99 017 5
    ARM chip.
    It came with vcds 22.3.0 and vcds loader v2 08.022.01.
    Under the test function the device is found successful.
    However, under vcds interface config I get the message "an interface must be connected by Usb to use this program"
    Can't run a scan, it shows "failure to communicate (0)".
    Cable is connected to the car with the ignition on.
    Can anyone help please?
  20. #11565
    Feb 2013
    Good day to everybody,
    I notice a strange message txt from VIIPlus loader at every startup of my second pc (W7 x64), and seems that many files into other software's folders are corrupted (corrupted and renamed with same message of the txt). It seems a virus of course, but it started after the last update of 22.3.1 ITT (with the fancy web page that ask you to confirm that you are using genuine interface). Anybody with same issue?
