Greetings to all! Has anyone tried clone Hex v2 on chip stm32f405 or stm32f415 for cars in 2021, Skoda or Audi with SFD lock? blocks are read? if you first remove the blocking of the sfd, is it possible to encode the blocks?![]()
Hey guys. I lost my cd of the chinese VCDS 12.12
May someone please provide a download link ?
THANKS![]()
hi, am I doing this right way,
i downloaded software from rostech site original 22.3.1
and from here i found loader 9. something,
and it works, reads codes, clears them
bud when coding the helper is not available, i have to manualy put codes in?
seal777 (3rd August, 2022)
Hello,i would be thankful if someone could help me.
I have 2 clone intefaces which dont work.Test is ok,but when i want to scan or something else,i get the messege:functions not supported by the gateway.I think the cause is that the interfaces were tried to use with the wrong software.
Is it possible to fix them?What should i do?I looked here on many pages and searched the internet,i found just partial or incomplete informations about it.I have not found anywhere what I exactly need to do,so i did not try anything in order not to destroy them completely.
Start with good quality pictures of PCB from opened cables.
Hello everyone!
After some years working fine, my ATmega162 interface stopped working correctly with VCDS 16.8 (that came on CD with it).
In details, VCDS doesn't show me options to calibrate Adaptive Cruise Control even if it sees correctly it's module (a couple of years ago was working fine) and from a week VCDS also doesn't allow me to enter and scan Engine Module (it recognizes the module and it's errors but when i try to open it the system doesn't preoceed.
I don't know what's the issue. Could they be problems related to VCDS? I already tried to unistall and install again the software provided with the interface, but the AAC problem still remains (i haven't tried a clean install for the new Engine Module problem).
Do you think a software update to newer versions of VCDS could solve my issues?
Also, I downloaded VCDS 20.4.2 and 9.2 Loader and the software recognizes my interface but, when i TEST it at the beginning, it shows me "not plugged into car" even if it is.
Is it related to an old firmware version of my interface?
I already made HD photos of my interface PCB.
May someone please help me?
Thanks!
The problem may be the stc chip,you need to remove it,look on the forum.
Thanks for the answer!
I read about removing the STC chip in oder to update the interface firmware.
I think, from what I've read, that my interface must be updated in order to be compatible for VCDS versions newer than 16.8. Am I right?
Do you think that a complete update (VCDS and interface firmware) could solve my issues?
Also, I can't understand why these two modules suddenly can't be read and cleaned correctly. I use a laptop only for car diagnosis, never connected to internet (wifi and lan disabled) and with no antivirus nor firewall
Greetings. Anyone know suitable alternatives for MIC2920A-5.0WS voltage regulator?
MIC2920A is out of stock everywhere without any signs it might become available again in the near future
I can calculate ABS module codings for:
* Continental/Teves MK60EC1 and MK60;
* TRW systems in Passat B6 / B7 / CC /Tiguan;
* MK100;
* Bosch ABS8.2, ABS9.0 and ESP8.2, ESP9.0;
* EBC 460 (UP!, Mii, Rapid, CitiGo, Fabia, Toledo, etc) New!
* ... and other VW/Audi/Seat/Skoda modules.I can assist with repairing \/CDS interfaces.
@hid3 :
https://a.aliexpress.com/_uHFTCP
@Hid3
Your PM is full
look here, is what i used for VCDS but search more, maybe find a good price. This is my first item i found quickly.
https://www.ebay.com/itm/264955564784?hash=item3db09512f0:g:MPMAAOSwMShh06y 8&amdata=enc%3AAQAHAAAAoF1zluVMirlqDaLA1dP%2BUup56 fpBnIKBrc59xY87eQnuTQ9pz4Nak%2Fh6NMrFXh%2BMPxHDpeY dDv%2BC6QG%2Fj5O76AX9%2BIdjnZ0VKuBT%2ByXh1kywre1Ex Cf8MJzKTkgF%2F2Pmb5UCJZH75iVYPQsRYJOUpoSSOXtrmNXHF fpGXybBcDqSS8AYDptTwe0ihNXOpWd6iUpeVFvIt7tjGxHYUS4 WmlA%3D%7Ctkp%3ABk9SR9TKrp_WYA
Have we still got issues with latest vii plus loader and 22.3.1. Still can't get security access to work.
And what's the most stable vii plus loader and software version to use?
Thank you.
