Page 782 of 854 FirstFirst ... 282682732772777778779780781782783784785786787792832 ... LastLast
Results 11,716 to 11,730 of 12803
  1. #11716
    Jun 2020
    Quote Originally Posted by TechMonkey View Post
    Anyone know of any issues with the STM415 cables, cant access coding or anything software version 20.4.1. All greyed out.
    Delete, reinstall software. Block vciconfig and vcds on Firewall inbound and outbound.
    Then try again.
  2. #11717
    Nov 2022
    Cheers Billy, will give that a try 👍
  3. #11718
    Apr 2022
    Anyone have a software for this cable? Please upload it!
    HEX+CAN
    dual k and can /// usb
    other side of the cable says VAG17.
    thx
  4. #11719
    May 2010
    EU
    @kalibali9 post some pictures of the board and components of it.
    Sent from my VOG-L29 using Tapatalk
  5. #11720
    Apr 2022
    Hi Guys!
    Could I repair this cable? Its a china clone. I have USBasp programmer.
    Thank you
  6. #11721
    Apr 2022
    I did! post #11718
    thx
  7. #11722
    Apr 2022
    Quote Originally Posted by kaalis View Post
    I did, check it post #11719
  8. #11723
    Mar 2016
    hi,
    difficult to say because your pictures are in low resolution but if the chip on board is an atmega162 you can repair it and use it with last vcds version.
    see instructions in VCDSLoader_v9.2.zip
    https://mega.nz/file/FYE2UCiL#5N5rYe...-15hbV2BIPGx34
    Good luck
    Bye
  9. The Following 3 Users Say Thank You to mrle9 For This Useful Post:
    ecufix (8th December, 2022), mexanico1971 (13th May, 2023), paradajz (1st December, 2022)
  10. #11724
    May 2010
    EU
    Must be this cable with sanded down marking of U7 chip. Probably some kind of ftdi knockoff.
  11. #11725
    May 2010
    EU
    Quote Originally Posted by kalibali9 View Post
    HEX+CAN
    thx
    Try this. Disable antivirus and prepare for everything
    https://www14.zippyshare.com/v/mdKFouYA/file.html
    I doubt this could be updated to current version. Although you could try, nothing bad could happen.
  12. The Following User Says Thank You to kaalis For This Useful Post:
  13. #11726
    Jun 2020
    dose www.obd2cartool.com not post to the uk anymore? cant seem to make an account with uk as a option
  14. #11727
    May 2010
    Hello I have 22.3 VCDS on Atmega162, and it is stopped working.
    it is just blinking red.
    I tried to reflash it using USBasp and it is started.
    Can read and write flash. VCDS tests show K1 and K2 short to +12.
    It looks like that I'm able to enter into dev mode on cable when connect USBasp.
    Firmware looks ok, so what could be wrong with this cable?
    EDITED: Looks like all AM1 transistors are dead: Q1A, Q2A, Q1B, Q2B.
    Will replace them hope all will works
  15. #11728
    Nov 2022
    Quote Originally Posted by Billyym View Post
    Then try again.
    Still no joy mate, tried all that and still the same (09 Central Elec) just shows adaption and coding greyed out with 2 buttons available
  16. #11729
    Jun 2022
    Quote Originally Posted by Mastahh View Post
    check post #10, schematic vagcom_rev1_sch_Transistor OUTPUT.pdf.
  17. The Following User Says Thank You to ALVINKONG For This Useful Post:
    Mastahh (2nd December, 2022)
  18. #11730
    May 2010
    Cool, thank you it will be very usefull
