Page 43 of 854 FirstFirst ... 3338394041424344454647485393143543 ... LastLast
Results 631 to 645 of 12803
  1. #631
    Nov 2010
  2. #632
    autocargo's Avatar
    Happy New Year everybody. Got this vagcom 704 and updated to 805 and then to 908 using arash dumps. They work ok with both upgraded versions but got problems when doing autoscan. All works ok but when trying to erase faults resulted after autoscan it gives message that all faults are erased but in reality it does not erase any faults... After autoscan I have to access each module that had errors and delete them one by one. Anybody has encountered this? Is there a solution? Thanks.
  3. #633
    Oct 2008
    SLO
    Quote Originally Posted by SmrekcPRO View Post
    Hi to all!
    I've just upgraded my "noname" clone from 704.1 to 908 with files from post 453 and it works.
    Thank you for all the info that I found on this forum.
    Because somehow ponyprog doesn't work with my STk500 Atmel programmer, I just used PonyProg, to split "dump file" in two separate files (FLASH and EEPROM). Than I used CodevisionAVR to programm the Atmel.
    Another thing that I haven't found on the forum is, that my type of clone has programming connections already routed to the side of the PCB, so I just had to solder some pins to the holes and did not have to perform any soldering at Atmel pins (shown on Images below).
    BOT.jpg - ImageHost.org
    TOP.jpg - ImageHost.org
    Best Regards
    Smrk
    Hi!
    I have the same PCB.
    Would you tell me please, which pins are 1,2,3,4 and 12V in your picture TOP.jpg( six pins).
    Would you mark it, please?
  4. #634
    DK Veteran aminebot's Avatar
    Oct 2008
    Algiers
    Quote Originally Posted by autocargo View Post
    To erase faults click on Clear all DTCs button.
  5. #635
    autocargo's Avatar
    Quote Originally Posted by aminebot View Post
    Hello aminebot. This is what I do but and I even get confirmation that all DTC are erased but in reality they are not erased... I have to log on again on all modules with DTC and erase them. Thanks for helping.
  6. #636
    Dec 2010
    [quote]
    Quote Originally Posted by bircaboy View Post
    Hi!
    You can find it out with ommeter. On one corner of atmega you will find white dot on pcb - so then the first pins down(and on the left side of atmega) are 1,2,3,4-i think that it is invisible in the TOP picture becuase it is covered with stabilizer 7805. And on stabilizer - the right pin is +5V(output) and the right is +12 V-input (on the TOP picture)...So you can just check which pin is connected to which one(for flashing).
    in #615 posts i was explained that thing by tr3ce13,
    and in #510 pins 1,2,3,4 are marked next to white dot
  7. #637
    Oct 2008
    Algiers
    you clicked on button with red arrow or green arrow ?
  8. #638
    Newbie ciamardo's Avatar
    Feb 2010
    italy
    hi aminebot a simple question!!! your fantastic loader 1.0 for VCDS lite work with last version 1.1 of VCDS Lite???
    best regards
    Original Vag-Com HEX-USB+CAN Rev.B from Ross-Tech...
    ELM 327 chinese with 1.4b "genuine" soldering pic!!!
  9. #639
    Feb 2010
    italy
    hi from ross-tech online manuals
    "[Clear All DTCs]
    This function is only available when using a HEX Interface and is implemented in two ways. On pre-CAN vehicles, VCDS will access each control module and clear DTCs from each one individually. On vehicles using CAN for diagnostics, VCDS performs this function without accessing all the control modules individually if the Use CAN Command box is checked. If you are not using a HEX Interface then you'll need to go into each module that has faults to clear them individually. This function is also accessible from the Applications Screen"
  10. #640
    autocargo's Avatar
    I used the button with green arrow and looking at your picture I think I must have been pressing the wrong one all the time... Is that right?
  11. #641
    Oct 2008
    Algiers
    Quote Originally Posted by ciamardo View Post
    best regards
    No , it work only with VCDS lite 1.0 , and it does not work correctly with some computers.
    i will make a loader for 1.1 version when i got free time.
  12. #642
    Oct 2008
    Algiers
    it's the correct button , you tested on what car ?
  13. #643
    Feb 2010
    italy
    good news
  14. #644
    autocargo's Avatar
    Tested on many cars: Audi A4,A6 from 1995 to 2005, Ibiza 2007, Golf IV, Skoda Fabia, Polo....etc
  15. #645
    Oct 2008
    SLO
    Hi to all!
    Best Regards
    Smrk
    If someone have the same PCB like me, there is a picture with pins for solder.
    http://b.imagehost.org/0935/TOP.jpg
