Page 66 of 854 FirstFirst ... 1656616263646566676869707176116166566 ... LastLast
Results 976 to 990 of 12803
  1. #976
    DK Veteran aminebot's Avatar
    Oct 2008
    Algiers
    Quote Originally Posted by ironderek View Post
    Counting from the GAL16V8(right side):
    red-green-white-black
    In some interfaces , wire are inverted , verify using a multimiter if red wire is 5V and black wire is gnd with usb cable connected to PC.
  2. #977
    DK Veteran bibkare's Avatar
    Feb 2010
    B & H
    Quote Originally Posted by mattydr67 View Post
    Did you tried to reprogramm it again?
    Good luck
    yea i reprogrammed it with 3 different dumps and every time could work only with 704, but it's OK, i just wanted to show this kind of hardware and to ask others did they have any experience with it
  3. #978
    Feb 2010
    B & H
    Quote Originally Posted by PEDRO4053 View Post
    see this interface, it's almost the same
  4. #979
    ipejasinovic's Avatar
    Jun 2009
    Bosnia & Herzegovina
    704 version didn't have check for R family of FTDI chips, so that is why it's working. When 805 came out, devices was supplied now with R chips. R chips have unique sn, which can't be changed, so, Uwe figure out to make sn from Atmega to depend on sn from FTDI. So, you have some tree created: Devices with FT232B and devices with FT232R.
    Galletto 2012 v54 full with JTAG and Mini available
    Big Stars never dies:
    Colin McRae (1968 ***8211; 2007)
    Richard Burns (1971 ***8211; 2005)
    Georg Plasa (1960 - 2011
  5. #980
    Jun 2010
    Here
    I have a newer audi a3 2007 2.0 tdi i had the old odb 11 cable ,it wont recognise my car with the vcdslite i havd from here .will i need the hex can cable .and what version of vcds do i now need
    cheers for any help
  6. #981
    Feb 2010
    B & H
    Quote Originally Posted by Steve L1 View Post
    cheers for any help
    You need at least VCDS version 805 and hex can interface
  7. #982
    Jun 2010
    Here
    Quote Originally Posted by bibkare View Post
    Is that version available here ?
  8. #983
    Jun 2010
    Here
    i do not have permission to view the threads .whats this all about then ? i have been on here ages ....
  9. #984
    Mar 2010
    brasil
    Testing with a multimetro connected cable in the black pc +5v - white earth - red earth pulsed and green earth pulsed.
    The white thread didn't loosen of the plate ,a connection it would be like this:
    Black
    red
    green
    white
    Thank you
    Pedro
  10. #985
    Aug 2010
    So you couldn't install the driver?
    I suppose so.
    Install it manually
    The folder of driver it is the same one where is the VCDS installed.
    C:\Ross-Tech\VCDS
    Good luck
    Yes but I received the same message when I tried to install manually. I really not understand the problem
  11. #986
    Oct 2008
    Algiers
    Quote Originally Posted by slevesque View Post
    Execute DPInst.exe in the attached archive. it contain 64x drivers.
    ROSSTECH_Drivers_64X.rar
  12. #987
    Member ironderek's Avatar
    Jul 2010
    Hi, I have 10.6 interface which never worked- when I've got it said error -1 and software didn't won't to start. Interface has FTDI232BL inside, and doesn't have STC chip. I reprogrammed it with 805dump and everything works fine, but if I unplug it from computer and plug again, interface is no more recognized as Ross Tech. Then I have to program it again with .ept file, and again works only for one time until is plugged into computer and car, after when i unplugged it again to same problem. What is wrong?
  13. #988
    Feb 2010
    B & H
    Obviously your dump isn't good. Try to reflash it with 908 dump
  14. #989
    Nio's Avatar
    Mar 2010
    Nice work guys. Thanks.
    "IF YOU THINK PROFESSIONAL PEOPLE COST YOU A LOT, IS BECAUSE YOU DID NOT KNOW HOW MUCH WILL COST YOU AN UNQUALIFIED"
  15. #990
    Oct 2008
    On Earth
    When you have that eror and the softwear dosen't start, that is a chinese cracked softwear and you need for it a VCDS with Ft232RL inside.
    That sw it is made for that kind of interface.
    If you have a FT232BL inside reprogramm it with dumps ( you can find it in this thread ) and you'll use an original ross-tech softwear not that one that your interface came with it.
    Good luck
