Page 71 of 854 FirstFirst ... 2161666768697071727374757681121171571 ... LastLast
Results 1,051 to 1,065 of 12803
  1. #1051
    DK Veteran rsibiza's Avatar
    Wink
    Quote Originally Posted by PEDRO4053 View Post
    Ok Bibkare
    This is the easyest interface to write atmega.
    Check pins from atmega to pinholes...there are all connections u need to connect atmega,with better place than on atmega...lot more space.
  2. #1052
    Jan 2011
    Lithuania
    It's impossible to read the hole thread.I can read 6-7 pages per day,but new posts and pages arising in the higher value Please,tell me: is there solution how upgrade interface from 812 to 10.6 VCDS ,for free?
    Thank you
  3. #1053
    angelx431's Avatar
    Sep 2010
    BG Sofia Madrid
    Quote Originally Posted by art64 View Post
    Thank you
    10.6 VCDS ,for free?-NOT
  4. #1054
    DK Veteran KenshinPT's Avatar
    Mar 2010
    PT
    Thank you
    You can upgrade for free to 908.0
    Read the thread in "diagonal" and you will find the "HOW TO" very fast!
    Did it help? Push Thanks below
  5. #1055
    Jan 2011
    Lithuania
    It is low difference between 812 and 908 versions (I think) and work to do a lot,especially for me if I will be doing it the first time.So I will keep older version.Thanks.
    May will be 10.6 for free in future
    P.s. Why it's necessary to remove the STC chip, transistor and resistor?
    What kind of job doing this chip?In my interface the STC is.Transistors I not see at all.
    My interface a little bit difference others, who's pictures I so in the this threat,but built in the same or similar principle,I think.
  6. #1056
    Mar 2010
    PT
    Those components are there to reflash the 93Cx6 EEPROM everytime you power up the cable because sometimes VCDS will detect the cable as a clone and will erase the EEPROM.
  7. #1057
    Junior Member Dima_minsk's Avatar
    Jul 2010
    Republic of BELARUS
    Hello!
    VCDS 10.6 does not work with FW 1.83
    I checked all the dump from the forum!
    Who really works?
  8. #1058
    Oct 2008
    On Earth
    Quote Originally Posted by Dima_minsk View Post
    Hello!
    Who really works?
    You talking about firmwear 1.83 but you need ATMEGA dump too and I really don't know that this 10.6.0 it is for free.
    So you ned to files to reprogramm Atmega not just 1.83 that you find here in this thread.
    BTW dumps for VCDS 10.6.3 for sure dosen't exist.
  9. #1059
    DK Veteran bibkare's Avatar
    Feb 2010
    B & H
    Hello!
    Who really works?
    Did you just use flash 1.83 without corresponding eeprom, if you did it's no good
  10. #1060
    Jan 2011
    Lithuania
    Quote Originally Posted by KenshinPT View Post
    It is shame,but I will ask.
    What means reflash?It's like renew or delete and rewrite flash?Or simple show for VCDS?
    I was always thinking that the flash is like eeprom inside bigest chip like CPU.I am wrong?
    It seems where is no eeprom like 93x6 in may interface.Or might be this one in the picture is 93x6?
    It means that VCDS without STC can't delete eeprom?But can not VCDS control erasing?
    I'm not using internet in my PC.If I remove this component it means I can use?May will be other problems goes up?Or in my case,it is possible (removing STC) using vcds_908_flash from the this threat only?
    Sorry for too many questions
  11. #1061
    Feb 2010
    B & H
    Were you too excited when you wrote those questions 'cause none of these makes any sense, please rephrase, one by one and i will try to answer it asap
  12. #1062
    Junior Member max4ever's Avatar
    Romania
    Hi again! I flashed Atmega 162 succesfull but it gaves me the next error:
  13. #1063
    Mar 2010
    PT
    Reflash means reprogramming again the flash (memory).
    You're right... The botom IC you marked seems to be connected to the FDTI, thus it's the FTDI's external EEPROM... However I am not familiar with that reference! Give me a clean photo of that IC or write here the whole reference.
    If you have good dumps (908.0 arash dumps, for example) you don't need to keep reflashing that external EEPROM. Got it?
  14. #1064
    Jan 2011
    Lithuania
    VCDS reprograming memory or the interface it doing itself?
    I don't know that dump is exactly in my interface.
    Bottom IC is ATMLH924 45D 1 Z8J2310.
    Can somebody give me link about flash,please?
    It is too many information for me in one day
  15. #1065
    Romania
    @bibkare
    please view post http://www.digital-kaos.co.uk/forums...tml#post965598 and give me a solution! I'm a desperate man!
