Page 571 of 847 FirstFirst ... 71471521561566567568569570571572573574575576581621671 ... LastLast
Results 8,551 to 8,565 of 12704
  1. #8551
    Mar 2019
    Quote Originally Posted by stug854 View Post
    someone who can help me with these codes of failure, my car is an ibiza 6j
    not the right topic mate, for specific help on an error, just google the error code and you will find plenty of results
  2. #8552
    May 2018
    Just to inform
    VCDSLoader 8.0 + 18.9.1 PTT Working as well
  3. #8553
    Jan 2019
    This error with USBAsp
    And this is the interface
  4. #8554
    Jan 2019
    Quote Originally Posted by Fabio89 View Post
    Just to inform
    I'm use with 18.9.1 ITT and working well
  5. #8555
    Mar 2018
    Quote Originally Posted by mattdj View Post
    It would be right to show us what contacts of the programmer you connected to the scanner, write that yes, I connected everything like this, I rang everything with a tester and I am sure that everything is correct.
  6. #8556
    Aug 2018
    France
    Loader v8.0 works fine with last french vcds release 18.9.1 FRM
    big thanks kolimer !!!!
  7. #8557
    Jul 2019
    Hey community,
    according to the pictures i have HW 0x46, but HW_Type detects it as an HW 0x44...
    Identification: no connection from ATmega162 pins 34 and 35 to GAL chip.
    i checked it, and i have NO connection....so is the only option to flash the 46-hex-files with an usbasp?
  8. #8558
    Mar 2018
    Quote Originally Posted by TPmodding View Post
    Hey community,
    Take a high-quality photograph of the board from two sides.
  9. #8559
    Jul 2019
    I'm new here. Do you guys have a address for a good quality VCDS clone? I want to first try the possibilities before I purchase the original Hex-V2 cable. Thanks in advance.
  10. #8560
    Mar 2018
    Quote Originally Posted by alid88 View Post
    https://www.digital-kaos.co.uk/forum...=1#post3575874
  11. #8561
    Jul 2019
    Thanks for fast respone. I've second question, can you copy keys for MK7 GTD via VCDS?
  12. #8562
    Jul 2019
    Just contacted the support team and they say that Golf 7 GTD is not supported with the cable since cable doesn't work with MBQ. Is there any other option?
  13. #8563
    May 2010
    EU
    Just ask them again what else this cable can NOT do.
  14. The Following User Says Thank You to kaalis For This Useful Post:
    jan4 (12th July, 2019)
  15. #8564
    May 2011
    Egypt
    Default Hex net v2.2
    Can anyone help me to determine the lost ic number form my original hex net v2.2 as it totally burned and i can not identify it here is the pic
    IC U2
  16. #8565
    Jul 2019
    Quote Originally Posted by Roma77 View Post
    here you go my friend, thank you for your response!
