Page 491 of 847 FirstFirst ... 391441481486487488489490491492493494495496501541591 ... LastLast
Results 7,351 to 7,365 of 12705
  1. #7351
    Dec 2018
    Quote Originally Posted by paro44 View Post
    If you have Atmega, then check if you can flash with usb. If that doesn't work, then solder wires / make connections and use usbasp to flash (or other programmer). After that you can flash the language you want with usb connection.
    I flashed in English 18.9 without problems and German version was then without a license
  2. #7352
    Feb 2013
    Quote Originally Posted by batja View Post
    You tell us only a half of your story...
    Reflash by usbasp or USB?
    Reflash only english you have Valid Lincense For English - reflash again with German (test-choose ok for firmware update) - you gonna get Valid License for both languages.
    Now, something else I wanna show you:
    Temperature test with ATF and GAL HW version- enviroment power up 12v and connected to PC for about 10 min.
  3. The Following User Says Thank You to alexm1 For This Useful Post:
    batja (6th December, 2018)
  4. #7353
    Dec 2018
    Quote Originally Posted by alexm1 View Post
    I had 17.3 software with German firmware 46 and then flashed with usbasp. It works now but only English version with loader 7.1 Software 18.9 and if I German version shows it with the coding that it is not licensed version ... I must now HW Flash 0x46 german and then in the program VCDS make update? for it to work
  5. #7354
    Oct 2018
    SAM_2794.JPGSAM_2793.JPGHexv2. Using little pins for upgrade?
  6. #7355
    Jun 2016
    can someone help me to make my original hex v2 unlimited
  7. #7356
    Apr 2018
    Quote Originally Posted by kayne30 View Post
    Write pm to user hid3.
  8. #7357
    Apr 2018
    [/QUOTE] I must now HW Flash 0x46 german and then in the program VCDS make update? for it to work[/QUOTE]
    Yes.
  9. The Following User Says Thank You to rak183 For This Useful Post:
    batja (7th December, 2018)
  10. #7358
    May 2010
    EU
    Quote Originally Posted by DKa0S View Post
    What you want to upgrade in this cable - upgrade to atmega162?
  11. #7359
    Dec 2018
    Hello. I have a problem. When I flash my cable, my laptop battery shutdown. Now atmega no response, diode on cable no blink. I use usbisp
  12. #7360
    Apr 2018
    Quote Originally Posted by undercoversr View Post
    Try to reflash ir with USBasp again and report.
  13. #7361
    Feb 2013
    And double check programmer PINOUT and connections To Atmega.
  14. #7362
    Dec 2018
    I try reflash on usbasp and programmer sp200s - no response. When i connect 12v to odb pins diode on cable does not light.
  15. #7363
    Dec 2018
    you have to flash eprom and flash again and pay attention to settings of usbasp.
  16. #7364
    Feb 2013
    Ok, put 12v via obd2 and check voltage, with multimeter, on LM7805- IN (12v) and OUT(5V) Search PINOUT for LM7805. Midlle is common Ground.
  17. #7365
    May 2010
    If battery shutdown, 99% must unlock the uC. Paralel programmer or Atmega doctor.
