I can calculate ABS module codings for:
* Continental/Teves MK60EC1 and MK60;
* TRW systems in Passat B6 / B7 / CC /Tiguan;
* MK100;
* Bosch ABS8.2, ABS9.0 and ESP8.2, ESP9.0;
* EBC 460 (UP!, Mii, Rapid, CitiGo, Fabia, Toledo, etc) New!
* ... and other VW/Audi/Seat/Skoda modules.I can assist with repairing \/CDS interfaces.
Hi.
I have recently bought a new car, a Passat B8 2016 that is on the MQB platform.
I have noticed that my interface does not support the car fully, for example I don't get the complete description on some fault codes, it just says something like "new feature not supported by interface".
It tells me what part has caused the fault code but not why that part has triggered a code, this does not happen on all codes.
Is it possible to update my cable to fully support my car?
Pictures of cable:
https://i.imgur.com/2geoB3H.jpg
https://i.imgur.com/pUFyOrg.jpg
https://i.imgur.com/Xi8NUq8.jpg
If it's not possible to update, what cable should I buy? Or should I just buy the OBDeleven instead?
Regards Dennis
Anyone had problems to run VCDS 18.9 or 19.6.2 with loader in Windows 7 ?
I double click in loader, but VCDS doesnt open.
Another windows 10 works fine
EDIT. Even whitout loader, VCDS do not run at windows 7 service pack 1
is this atmega 162
https://sprzedajemy.pl/interfejs-dia...a9f-nr61023947
this is the cheapest site that sell vcds till now cant buy from china so im still searching
Hi, dear friend
all packages already shipped from 1th Feb, Our region is safe , No carriers have been found so far, The parcel post office pickup with quarantine and is very safe.
nicolas2015 (25th February, 2020)
MQB platform is not supported unfortunately.
Your cable has the 5 pins interface for updating, you should also check if bootloader is unlocked, you can use VAGCOM_HWType.exe from the Kolimer loader archive for that.
But even if you update, MQB is not supported by any of these clones
I think OBDeleven would work
Szia aktiválná nekem egy vcds betöltőt 1.12.
Hi friends
Thanks to "obd2cartool" for updating information. Encouragement to Chinese friends to fight this misfortune.
I also wanted to order items but given the situation i was in doubt, so you confirmed that the shipments are active
(may be longer but still in progress?)
Thank you.
Hello, I need your help, during flash and eeprom upload, progisp threw the message "Flash Verify Error at: 2h"
And I lost my connection to Atmega162. How can I resume the connection to try to program HexV2 again?
When he tries to resume the connection, a message pops up "Chip Enable Program Error"
Everything set up as a textbook
Thank you. I could make it..Kolimers loader V 7.1. There is a PDF file with instructions and photos on how to update, repair the cables.
