Page 509 of 847 FirstFirst ... 9409459499504505506507508509510511512513514519559609 ... LastLast
Results 7,621 to 7,635 of 12691
  1. #7621
    Mar 2018
    [QUOTE = mikroel; 3469662] Я кратко проверил вашу печатную плату и у меня есть один вопрос?
    где 22pF подключен, одна сторона подключена к OSC 7,37 МГц, а другая сторона конденсаторов в воздухе? ​​[/ QUOTE]
    everything is good the second side on gnd
  2. #7622
    Jan 2010
    Trstenik - Thun
    Quote Originally Posted by Roma77 View Post
    все хорошо, вторая сторона на gnd
    yes yes i saw in the mean time.
  3. #7623
    Mar 2018
    With such success, friends will soon come to this topic RT and offer a contract for the development
    Xoom Thank you, I just uploaded your gerber archive to JLC
  4. #7624
    Jan 2019
    CZ
    Hi, thanks for your help but in adaptation group "Axxx" there are not these channels :/ It's like a puzzle
  5. #7625
    Mar 2018
    Quote Originally Posted by Mrjitter View Post
    i put the zener component, but its a normal diode . Its for apply 5v from usb to all circuit, to program the atmega. Not neccesary 12v from OBD connector .
    I have not usbasp, i have old stk500 program interface. This interface has not 5v to supply atmega.
    Regards
    Then you can even reduce the cost of your scheme, throw away 2x9637 + 7812 = comparator lm339
    https://i.imgur.com/d42eO24.png
  6. #7626
    Newbie Mrjitter's Avatar
    Dec 2010
    Spain
    I certainly don't understand how I could reduce the cost. but the goal is not to reduce costs, it is to have a 100% operational interface.
    I'm not a vagcom expert, I had an interface like the one in the attached image, it broke down and I used the gal coming from this interface for mine. But when I tested it on an audi a3 2006 year, the interface doesn't erase faults. I had the doubt if the scheme was the right one.
    Regards
  7. #7627
    Mar 2018
    Regards
    Honestly, I stumbled what you want, you wipe out your schemes and boards, then write that you don't even have a normal GAL and programmers, sorry, I don't understand you, can anyone else understand and help
  8. #7628
    Dec 2010
    Spain
    it's simple ....
    Is the scheme posted above ok for use with a type 44 gal jed file and kolimers firmware 0x44 ?
    Regards
  9. #7629
    Mar 2018
    it's simple ....
    Regards
    then everything is simple .....
    collect and check
  10. #7630
    Dec 2010
    Spain
    collect and check
    Yes ....is made and tested in a audi a3 . I don't have a gal programmer yet, so I used the old one.
    The result is that after making an autoscan and finding several faults, the interface does not erase them, for this , i doubt if the scheme was correct.
    Greetings and thank you for taking the time to answer.
  11. #7631
    Aug 2009
    I think you need to know type of broken interface, donor gal, x44 or x46. And after that, program ftdi and atmega with corect informations.
  12. #7632
    Dec 2010
    Spain
    Quote Originally Posted by flavyus1987 View Post
    This is the interface .... i think it is 0x44
    Regards
  13. #7633
    Jan 2019
    Best Country of the world, GR
    Hi, is it possible this cable (soft. 12.12) to upgrade easy?
    https://ibb.co/fNL4zTC
    https://ibb.co/PwzGgc6
  14. #7634
    Jul 2016
    Vilnius
    Yes. For me it would be very easy.
    I can calculate ABS module codings for:
    * Continental/Teves MK60EC1 and MK60;
    * TRW systems in Passat B6 / B7 / CC /Tiguan;
    * MK100
    * Bosch ABS8.2, ABS9.0 and ESP8.2, ESP9.0;
    * EBC 460 (UP!, Mii, Rapid, CitiGo, Fabia, Toledo, etc) New!
    ... and other VW/Audi/Seat/Skoda modules.I can assist with repairing \/CDS interfaces.
  15. #7635
    Jan 2019
    I will immediately start reading 508 pages!!
