Page 494 of 494 FirstFirst ... 394444484489490491492493494
Results 7,396 to 7,410 of 7410
  1. #7396
    Jul 2018
    Downloads
    Uploads
    Ok thank you
  2. #7397
    Oct 2018
    Downloads
    Uploads
    Good day, Thanks for the new bootloader. What are the differences from 7.1 .
  3. #7398
    Jun 2016
    Downloads
    Uploads
    Quote Originally Posted by hid3 View Post
    I think he asked fot GAL/ATF firmware, not dumps
    Maybe someone knows the Vcc pin number on "HEX-V2" programming header? Thanks
    Please help me with my hex v2
  4. #7399
    Dec 2018
    Downloads
    Uploads
    I would like to say a massive thank you. I managed to reflash a vcds clone up to 18.9 and everything is working perfect. Also thank you to Kolimer for his software. ps i have never done anything like this before so cheers guys.
  5. The Following User Says Thank You to Mchele2000 For This Useful Post:
    kaalis (13th December, 2018)
  6. #7400
  7. #7401
  8. #7402
    Dec 2018
    Downloads
    Uploads
    Hello, i have this cable i bought 2 or 3 years ago. It is working with software provided by manufacturer, but I can't access stuff like radio, headlight range or save long coding. Is there anything I can do with this cable, or just buy new one?
  9. #7403
    Mar 2018
    6
    Downloads
    Uploads
    Quote Originally Posted by Syrxes View Post
    just buy a new, NEC-bad.
  10. #7404
    Dec 2018
    Downloads
    Uploads
    Any advice on where to get new one? Iíve seen a couple sites, but most of them seem sketchy
  11. #7405
    Jul 2016
    Vilnius
    22
    Downloads
    Uploads
    Obd2CarTool.com is the trusted source here..
    I can assist with repairing \/CDS interfaces.
    ABS module codings:
    * MK60EC1 and MK60;
    * ABS8.2, ABS9.0 and ESP8.2, ESP9.0;
    When requesting ABS coding, please supply all the information listed here.
  12. #7406
    Dec 2018
    Downloads
    Uploads
    Thank you very much for your time.
  13. #7407
    Downloads
    4
    Uploads
    thank you for your good work kolimer
  14. #7408
  15. #7409
    Jan 2011
    Downloads
    Uploads
    Hi @all,
    I used for a long time the old 908 dump with my 232BM cable. Now I have read about the loader solution. In the info file it will described to cut the line between STC Pin9 and resistor R50. But on my PCB the Pin9 is connected to a transistor T5. Only Pin8 is connected to resistor R50. Which connection should I cut ?
    thx
    Mario
  16. #7410
    Jul 2016
    Vilnius
    22
    Downloads
    Uploads
    If you can, desolder STC completely and be done with that
    ABS module codings:
    * MK60EC1 and MK60;
