VAG-COM/VCDS EVERYTHING - Page 644
Page 644 of 644 FirstFirst ... 144544594634639640641642643644
Results 9,646 to 9,656 of 9656
  1. #9646
    May 2010
    EU
    117
    Downloads
    Uploads
    So, 2Q-19.clb doesn't contain redirect for your 2Q0-937-089-B.
    That's why you copied 5Q0-937-08X-V2.clb to Labels\User and renamed to 2Q0-937-089-B.clb
    You see that clb file gets read in your opened #09 controller.
    Anyway, this file doesn't support coding information. It has security access code 31347 for J519 adaptation enabling.
  2. The Following User Says Thank You to kaalis For This Useful Post:
    Fabio89 (4th July, 2020)
  3. #9647
    May 2018
    14
    Downloads
    Uploads
    Quote Originally Posted by kaalis View Post
    I saw label get read now after you said that.
    i will try put security access and see if adaptation enables
    Thank you
  4. #9648
    May 2010
    EU
    117
    Downloads
    Uploads
    ITT, PTT and EST released.
  5. #9649
    Jul 2019
    5
    Downloads
    Uploads
    also with Loader 9.2
    by Audi A4 or VW Touran after 2016 doesn't work good and you can not read the 53. Brake settings
    can someone tell me if there is a new update Loader from Kolimer that can solve this problem?
    Thanks a lot Kolimer and all Digital Kaos Users
  6. The Following User Says Thank You to AlexKudry For This Useful Post:
    lolren2 (5th July, 2020)
  7. #9650
    Jul 2020
    Downloads
    Uploads
    Hi all. I've started to read all the posts, but it will take some time as English is my second language
    Until then, just wanted to ask about my VCDS clone. It works, but it says CAN: not ready. I will require to activate my cd changer function in my cd player. When i scan for radio, it communicates with it( volume change) but i get a error saying : too many errors.
    It's there a way to reflash it?( Hw type shows 1.96 and no info about bootloader)
    Kind regards, Loren
    Edit: yes, it has the Atmega 162 chip inside
    Sent from my Redmi Note 8 Pro using Tapatalk
  8. #9651
    Top Poster razor1199's Avatar
    Feb 2017
    Poland
    113
    Downloads
    Uploads
    Will this 9.2 Loader work with AKP 20.4.1 (Polish)?
  9. #9652
    Top Poster kowalwalcz's Avatar
    Dec 2009
    25
    Downloads
    9
    Uploads
    Quote Originally Posted by razor1199 View Post
    Yes working
    if I helped You, press the button THANKS
  10. The Following User Says Thank You to kowalwalcz For This Useful Post:
    razor1199 (7th July, 2020)
  11. #9653
    Jul 2020
    Downloads
    Uploads
    Thanks to a forum member, I've managed to flash 1.96 using vagcom eewritelang( bootloader is enabled), but, sadly problem persists( can: not ready). When i scan the radio, for example, i get the volume changed as it scans, but then i get : too many errors to continue. You guys think is a hw issue? Thank you
  12. #9654
    Jul 2020
    Downloads
    Uploads
    Default NISSAN SUNNY PINCODE
    Quote Originally Posted by kowalwalcz View Post
    Yes working
    HI I NEED A PINCODE FOR NISSAN SUNNY
  13. #9655
    Sep 2013
    Downloads
    Uploads
    20.4.1 Spanish version works with 9.2
  14. The Following User Says Thank You to imedia00 For This Useful Post:
  15. #9656
    Aug 2018
    Downloads
    Uploads
    Hi, after update the vcds to latest version vcds loader 9.2 with all success, bit i have got one error: Can Unavailable
    https://ibb.co/vjv9MD3
    https://ibb.co/FKqH5VQ
    https://ibb.co/ZM4Txty
    Any fix for it?
