Results 1 to 15 of 28
    Oct 2008
    Default Beginer needs help with technomate 6800hd
    Hi to all
    Please
    Can any member of this community give me some info on what I can do with this box and where the information is to learn myself on how and what to do, to increase my enjoyment with it
    Administrator
    Devilfish's Avatar
    Feb 2008
    I've uploaded the latest patch for you here...
    http://www.digital-kaos.co.uk/forums...-09-08-a-9981/
    Also check out the sticky threads at the top in red.
    Oct 2008
    Thanks will look at threads and get back , its all new takes time to get understanding
    Thanks again
    Retired Sat TV Addict
    .: JaCkPoT :.'s Avatar
    Aug 2008
    var/tuxbox/plugins
    Im technomate addict. Ask me any questions and i shall answer. Willin to give you as much info as you need.
    Read the Rules here; they apply to Everyone.
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Technomate 2300 Motor
    Oct 2008
    Thumbs up
    Sadiq
    I will definetly contact you with loads of questions , over the coming weeks , As i am a complete novice to it,
    thanks for your offer
    oldman
    Aug 2008
    var/tuxbox/plugins
    your welcome mate, here to help
    ___________________
    DM800s HD
    Openbox S10
    TM500
    DM500s
    Oct 2008
    I have a huge problem with my technomd 6800Hd, i was trying to update it and it just stop working completely it did not respond to anything again.I was using usb pen. help please
    V.I.P. Member benny/9's Avatar
    Nov 2008
    north west uk
    Quote Originally Posted by ebunmiebun View Post
    hi m8,
    you will now need to do a forced download to clear the box,
    first have you got a null modem cable?
    this is how you do the forced download
    [1]download the darkman v187 loader panel from the forum
    [2]download the patch. open the zip folder and get the patch out ready to load,
    [3]connect the null modem cable from the com port on your computer to the rs232 port on the rear panel of your receiver
    [4]turn the receiver off with the switch on the rear panel near the rs232 port
    [5]open the v187 loader panel click and set it to software and download the panel usualy opens on this setting then browse button and find the patch on your computer and left click the patch then click open on the window
    this will load the patch onto the loader panel
    [6]click connect on the loader panel and when you see on the loader panel
    [ connect your receiver and turn on] go to the receiver and turn it on with the rear panel switch and this will then force download the patch and clear the problem and load the patch now your receiver will work as normal again, after this you can use your memory stick for all the
    software/patch/softcam/chn list programming again
    Please Read Carefully!
    No Sky UK NDS Videoguard Hacking Discussions.
    Viewing Pay TV without a valid subscription is illegal
    the files available are kept for experimental & educational purpose only
    original vu duo2 /vu zero/ tm-nano-se. v-box / 36v /1.2 dish,
    Oct 2008
    thank you very much, i have not tried it yet but i can trust, whatever i get from here, but i do not know where to get darkman v187 loader panel
    Nov 2008
    north west uk
    this is the way to clear your receiver mate, a lot who buy tm receivers dont load the first patch with the null modem cable and from the posts i see these are the users who have most problems with the box locking up
    make sure if you dont have a cable you buy a null modem cable [female-female] plug ends these look solid with 9 pin holes in each plug. if you see 9 pins in one plug end this is a serial cable.this is the v187 loader you need for use with the cable on your model
    Aug 2008
    var/tuxbox/plugins
    Dont hesitate to use do the forced download.. It cant do anything... All the info on here is fully revised and always is before being put on the forums... We will not give any false info....
    The forced download has saved many receivers to this day and will continue to do so... It is very handy but only for the new5000,1000 and 6000 supers and normals...
    It does not work on the 3000,2000,7000,8000,9000 or the old 5000.
    ___________________
    DM800s HD
    Openbox S10
    TM500
    DM500s
    Oct 2008
    thank you, i am very pleased to be part of this community. however i tried to unzip darkman loader, but i got a message it is either unkown or corrupt.
  13. #13
    Nov 2008
    north west uk
    hi m8,
    i have just removed the v187 loader file and found it
    downloaded and opened>ok i have reposted the file
    give it anouther try
  14. #14
    Aug 2008
    var/tuxbox/plugins
    Downloaded here and works.. Try firefox..
    ___________________
    DM800s HD
    Openbox S10
    TM500
    DM500s
  15. #15
    Oct 2008
    Default re downloads
    Had loads of problems with downloads using Ie 7 use firefox after advise from benny no issues ever now. Great forum, had loads of help to get up and running. keep up the good work
    mooreand
