Hi, please help off the lambda
Audi A6 car is a 3.0 220hp ME7.1.1
Rear lambda, or catalyst?
Hi ddillenger84, catalyst
lambda regulation is necessary, you can remove lambda for cat status
This will help anyone?
Here you go. No password required
seba_m_ (5th February, 2015)
Work. Thanks.
Hi.
Year your car ??
How do you read this ECU ???
and you take a risk for read me7.1.1 via obd?
how to find a problem!
me7.1.1 always bootmode or desolder is the best way for work and safe money
Hi carmageddon!
Please provide details on the risks of reading and writing of the ECU me7.1.1 via the OBD.
Regards.
any serious tuner advise hes client that this model of ecu have protocols instable and bad hardware (wrong quartz and clock gen) and recommend to do R-W only with boot or desolder flash.
obd writing often corrupt e2p or mpc
2xded (6th February, 2015)
read previous post : any tool that can work on boot mode or desolder is the only safest way
abcdef (5th February, 2015)
This is not true. On later ST10 ecus, yes. This one is still C167R, MPC is one time write and cannot be corrupted. This ecu also does not suffer from programming errors such as P1681.
There is no danger to read/write this ecu via OBD. An OBD read can be used to recover in bootmode, and the eeprom is generic as well.
