Results 1 to 7 of 7
    Oct 2019
    Default rns-315 with 8k ops in fabia 5j vrs 1.4 tsi
    Hello there, I have retrofit complete ops oem pdc in my fabia rs . The car is equipped with rns-315 Amundsen+ with partnumber
    Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
    Part No SW: 5JA 035 193 E HW: 5JA 035 193 E
    Component: RNS315-EU H85 0501
    Serial number: SKZAZ2R0659899
    Coding: 040004110400000000000001
    Shop #: WSC 12345 123 12345
    ASAM Dataset: EV_RNS315EUV2UDS 001705
    ROD: EV_RNS315EUV2UDS.rod
    VCID: 3A7B6964BDC93E9AD3-806E
    Data medium:
    Subsystem 1 - Part No: 3AA 919 866
    Component: EUR_W_V11 0073
    and pdc part number
    Address 10: Park/Steer Assist (J446) Labels:. 7E0-919-475.clb
    Part No SW: 7E0 919 475 S HW: 7N0 919 475
    Component: PARKHILFE 8K H06 0210
    Revision: -------- Serial number: 28261530202208
    Coding: 108101
    ASAM Dataset: EV_VW75XParkAssis8K 001011
    ROD: N/A
    VCID: 428B1184D519765A8B-8016
    the problem is that I can not change the car type from an Octavia 2 sedan to a hatchback .
    I have tried everything but nothing happens
    can any one have an idea what to do ?
    A friend of mine told me about ecu reflash in rns-315 , I am posting photographs above
    Kind regards
    vv
    Oct 2019
    Hello everybody is it possible to make an ecu reflash?
    regards
    vv
    Oct 2019
    maybe in your firmware version there are simply no pictures of the needed cars. RNS-315 is flashed using the CD
    Oct 2019
    [QUOTE=pvc1;3698037]maybe in your firmware version there are simply no pictures of the needed cars. RNS
    Hello , so I need some kind of cd to upload more cars ? Do you know who will provide this cd ?
    V
    Dec 2017
    Set right car in gateway !
    Oct 2019
    Hello , the car set in getway is correct
    regards
    VV
    Sep 2018
    Hi , have you ever found a solution to that problem ?
    I have a very similar problem on a seat toledo.
    The car is sedan , it is shown correctly as a toledo on the ops screen ,
    but on the rear view camera screen with mini ops it shows a seat alhambra.
    Unfortunately vcds does not provide descriptions or a label file for the seat version of the same radio so I can not find what is wrong.
    Address 10: Park/Steer Assist (J446) Labels:| 1Sx-919-475.clb
    Part No SW: 1S0 919 475 B HW: 1Q0 919 475
    Component: PARKHILFE 3K H03 0013
    Revision: -------- Serial number: 32931715705623
    Coding: 308001
    Shop #: WSC 31414 790 00001
    ASAM Dataset: EV_EPHVA14VW1200000 001009
    ROD: EV_EPHVA14VW1200000.rod
    VCID: 397998E3B8599B4C05-806C
    No fault code found.
    Address 37: Navigation (J794) Labels:* None
    Part No SW: 6JA 035 192 L HW: 6JA 035 192 L
    Serial number: SEZAZ2P0566811
    Coding: 040004710200000000000001
    Shop #: WSC 73430 790 00137
    VCID: 4189F003D089C38C4D-8014
    Data carrier:
    Component: EUR_W_V12 0078
