Results 1 to 9 of 9
    sdnatlst's Avatar
    Aug 2011
    England
    Default nissan note 2010 - no remote central locking suddenly
    hi, had a customer today call me out
    remote central locking stopped working,
    he has spare remote key which has never been used - customer had car from new - also not working.
    1. i tried frequency output both remotes - fine
    2. i tried diagnostics on bcm unit - no fault codes
    3. i tried battery disconnect and pulled all the fuses in the interior box where obd socket is
    4. central locking button functions inside the car fine
    what coud this be? it was all of a sudden, customer came out from shop and remote didnt work.
    Tools owned -
    Mar 2018
    UK
    Recently I had the same problem with Qashqai 2008 - Still not sorted
    Usually problem is faulty central lock on drivers door
  3. The Following User Says Thank You to Manta1600 For This Useful Post:
    sdnatlst (18th June, 2019)
    super jumbe's Avatar
    Livingstone
    Nissan cars Note/Qashqai has issue with remotes suddenly stopped working rumours you will need a new control unit!!!
  5. The Following User Says Thank You to super jumbe For This Useful Post:
  6. #4
    sdnatlst's Avatar
    Aug 2011
    England
    Yes i told customer to take it to Nissan as i suspected issue with BCM,, so sounds like my advice was right.
    thanks all
    Tools owned -
  7. The Following User Says Thank You to sdnatlst For This Useful Post:
    super jumbe (18th June, 2019)
  8. #5
    Dec 2010
    Nottingham
    also caused by faulty ignition , when car doesnt see ignition is fully switched off . had this on a 2011 quashqai , remote not working and wouldnt allow me into programming mode , after new ignition all was fine. the give away was no warning beep when key in ignition and door opened .
  9. The Following 3 Users Say Thank You to rapidlocksmiths For This Useful Post:
    castin (21st July, 2019), Manta1600 (18th June, 2019), sleepyrz (19th June, 2019)
  10. #6
    Feb 2014
    Disconnect plug from switch that tell you key is in ignition and remote should work again.
  11. The Following 2 Users Say Thank You to doolittle For This Useful Post:
    Manta1600 (25th June, 2019), sleepyrz (19th June, 2019)
  12. #7
    Mar 2018
    UK
    Quote Originally Posted by doolittle View Post
    I tried this on Qashqai without success
    Today I conected autocom to Note (on this car remote work OK) and in BCM I saw that has options to check remote
    then I connected auttocom to Qashqai and there no conection with BCM
    So in this case Super Jumbe maybe is right
    Can I directly swap the BSM with second hand or must be virgin and coded?
  13. #8
    Jan 2014
    sound like jumbe i am hang on with it
  14. #9
    castin's Avatar
    Oct 2015
    Micra K12 - faulty ignition key switch. After unplug connector remote work again.
