Page 3 of 3 FirstFirst 123
Results 31 to 44 of 44
  1. #31
    UK
    Had similar problem with AK90 . Used bin file on zedbull to produce transponder that worked fine. Which means my AK90 was reading good but some error on writing transponder ! Advise use your file with alternative tool for transponder
  2. #32
    fred77's Avatar
    Jun 2019
    never had problem writing chip - never
    and I've done 200+ and speak with experience about issues. what problem you have is you should write to un-used slot and then write back to eeprom.
    job done everytime - all the time.
    *** If file not recognised by AK90 *** then use another editor like AVDI tagtool or guess Zedfull or tango.
    Then load back into AK90 and write back.
  3. #33
    Mar 2018
    UK
    Quote Originally Posted by fred77 View Post
    Maybe you must program 500+ to find out that no need to write back
  4. The Following 2 Users Say Thank You to Manta1600 For This Useful Post:
    Fallen (9th December, 2019), lion0304 (9th December, 2019)
  5. #34
    Feb 2018
    Glasgow area
    Ak90.
    Read EWS.
    Write key.
    Done.
    No need to write back if all you're doing is programming a new key to an unused slot.
    I've done hundreds too and can't think of any failures.
  6. The Following User Says Thank You to PixelsFixed For This Useful Post:
    Manta1600 (9th December, 2019)
  7. #35
    Nov 2019
    Wales, UK
    Thanks for all the suggestions so far, had another look at the EWS in BMW Scanner and checked the status of the keys in live data, as per usual the new keys show Wrong Fixed, Random and Password. Aligning EWS DME in BMW Scanner fails to do it. Switched to INPA and tried to do it in there I get Rejected error messages for password and fixed code. Back in BMW Scanner I noticed that it reports the EWS Programmed and Locked. Could this be the reason my keys fail?
    Only found one example of this problem on the web and he got it resolved by an independant who went into the EWS, story here
    http://www.e46zone.com/forum/topic/6...s-help-needed/
    This was on an E46 where mine is a E85 BMW Z4 with EWS3.3.
    I cannot see any way in any of the software I have to unlock the EWS, BMW Scanner has the ability of Unlock and Erase but dont have the balls to do that in case I wipe the one working key I have.
    Probablr going to see an independant who has quoted me £150 to sort it once I have fresh transponders delivered. I do know they go into the EWS using something like BMW Editor.
  8. #36
    Oct 2018
    Northern Ireland
    You’ve exhausted all your options and probably spent in excess of £150 on tools, keys and transponders. This would have got you a spare key hassle free. Quit while your ahead before you damage the EWS unit. Get a lockie in with the proper gear or you might end up regretting it.........
  9. The Following User Says Thank You to Jimmy07 For This Useful Post:
    colb (9th December, 2019)
  10. #37
    Nov 2019
    Wales, UK
    Nowhere near near £30 spent as only outlay so far was on that awful AK90 machine and a couple of keys off ebay already had the other software. I think your probably right about getting a lockie to sort it, I think it all boils down to the EWS being locked. Key status when viewed in BMW Scanner shows 1 -3 used and enabled auto init also enabled. The remaining key slots show enabled but aut init is not which leads me to believe BMW locked the EWS to prevent joe bloggs adding new keys. Only found one instance of the same locked EWS on the Web which was resolved by independant going into it and changing a key number from 4 to 0 on an E46. Just wonder what key would BMW supply if I went down that route, I suspect it would be No.4, but how would the car accept that if the EWS is locked? Would they then want the car to unlock the EWS to get the key accepted?
  11. #38
    Oct 2018
    Northern Ireland
    Usually dealership will give you something like slot 3 or 4 seen this before and key not starting the car as slot used. Get a decent lockie before you corrupt EWS then it will be a lot more than £150 to put right
  12. #39
    Feb 2018
    Glasgow area
    You've buggered about with it so much that there's a good chance a BMW key won't work. The guy in your forum post clearly has a replacement ews fitted from a different car.
    https://m.facebook.com/story.php?sto...41597829647098
    Pasoft always says ews is locked and behaves as you describe.
    I charge £80 for a diamond key supplied, cut and programmed and I'm not the cheapest!
    Send me your module - after you've refitted it and started the car - and a blade to copy and I'll guarantee you a working key or no charge.
  13. #40
    Jun 2015
    I've used the ak90 more times than I can count and have never had to write the bin back to the EWS. If your chips are good, it sounds like your tool is faulty.
  14. The Following User Says Thank You to patlock For This Useful Post:
    sleepyrz (12th December, 2019)
  15. #41
    Jan 2017
    USA ����
    Yup said that a while back
    Wouldnt write a damn thing to the ews if its known to have writing errors like that
    Although it is through different methods
    Rf vs direct connection
    Still its a bad box regardless
  16. #42
    Oct 2018
    I shall be the attending locksmith tomorrow I might add ;p
  17. #43
    Nov 2019
    Wales, UK
    Result, sorted at last, local Lockie came out and within 20mins had it sorted, using Zed-Full coded diamond key to slot 8 which when tried in the car failed to crank, recoded to slot 3 which was a known used slot and that worked first time. Coded after reading the eeprom which was beyond me, not got the kit to do that. It would seem that the previous time I coded that key to slot 3 with the AK90 it didn't code correctly, reckon the AK90 I have is faulty given that so many others have success using it. Would have been good to have completed the job myself but what were the chances of getting it done if a laid out another £50 on a BMW Editor set up? Given the cost of his kit I don't think I was overcharged even as I had my keys cut already. Very pleased now I have two keys and both are synced up for remote locking which was very easy to do. Thanks Ed, I know you frequent the forum.
  18. The Following 2 Users Say Thank You to colb For This Useful Post:
    bioggy (14th December, 2019), Minnovations (11th March, 2023)
  19. #44
    Oct 2018
    That would be me, glad your happy with the result Zed-Full with the ews3 cable programmed through the board
  20. The Following 2 Users Say Thank You to bioggy For This Useful Post:
    colb (14th December, 2019), Minnovations (11th March, 2023)
