After swiftec i get after 1000km DPF symbole in dashboard and in diagnostic 0dtc it is mean soot level still grow up.
Hello Friends
I have problem with Honda Civic 2.2 I-ctdi edc16.
After reset calcualtors of DPF and write to ECu Swiftec solution v2 DPF off car works ok, no errors but after some km regeneration is start
Somone has a good solution for this ECU?
Please help if You can
ory kess edc16c1-7 kline.rar
Luca
PLEASE PUSH THE BUTTON THANKS IF MY WORK HAS HELPFULL
AND REPUTATION BUTTON (starr)
Corect DPF OFF For you pass Thenks and Reput
luca22 (15th April, 2017)
Hello eurofix
Still have problem with Honda 2.2 i-ctdi
On your file the car has no errors, it does not regenerate but catches regular emergency mode without recording the DTC and sot lvl of DPF up in ECU calculator
Swiftec support don't answer for this problem
Turbo and injectors are good.
Are temperature and differential sensors to be disconnected?
Someone has 100% solution for this ECU?
I greet and thank you in advance for your reply
Luca
try this, reset %dpfory kess edc16c1-7 kline dpfoff.rar
darka7 (1st September, 2020), Konstantin UK (22nd March, 2019), luca22 (2nd May, 2017)
Merci khou
Working? I have similar problem like you. Another cars working property but not this SW :/ Maybe some sensors temp. or diff pressure are broken?
If I helped you please remember to give thanks and rep. A little thanks goes a long way
Konstantin UK (22nd March, 2019), luca22 (12th June, 2017)
Oh. I didnt look at the date
