Results 1 to 7 of 7
    Newbie Kreigen's Avatar
    Dec 2018
    Russia, Moscow
    Default Dodge Grand Caravan 2009 fobik
    Hello! Help me please.
    obdstar x300dp can not read the pin code from this car on OBD2.
    What other ways are there? Maybe there are free calculators for VINtoPIN?
    In which block and which EEPROM is installed?
    Sorry for my english. Google Translate
    ray-ray's Avatar
    Key tumbler style is Pacifica System no obd2 pin read,must remove and read the skim module. Screem module is connected to the Ariel are the barrel.
    Dec 2018
    Russia, Moscow
    OK. And what is there to read? eeprom? 24c16 or 95080?
    narkeleptk's Avatar
    May 2017
    USA
    What are you talking about RayRay? No 2009 Caravan uses pacifica system. There are two types of fobik systems on 09, both you can read pin via obd. Some tools only have the one type listed for the model. This maybe your issue with tool. You can try selecting other fobik model cars in your tool.
    On older style WIN units (ignition) pin is in a so-8 eeprom. On newer style WIN units its in nec mcu.
    Dec 2018
    Russia, Moscow
    There are 2 points in x300dp:
    CARAVAN FOBIK A (2009-2010) - there is no function to read the PIN code.
    CARAVAN FOBIK B (2009-2010) - there is, but does not read the pin
    Maybe FVDI or SKP-900 can?
    narkeleptk's Avatar
    May 2017
    USA
    CK100, Ikey820, FVDI will do it yes. I don't have skp900 but I assume it can as well.
  7. The Following User Says Thank You to narkeleptk For This Useful Post:
    Kreigen (29th August, 2019)
    Dec 2018
    Russia, Moscow
    Thank. I will check other devices
