Page 2 of 2 FirstFirst 12
Results 16 to 27 of 27
  1. #16
    ilen's Avatar
    Feb 2013
    Serbia
    Quote Originally Posted by lwd11 View Post
    I modified dump, now the radio is playing without code.
    Here you are Attachment 438949
    thanks for the help
    nice job friend... ...
  2. #17
    Jun 2016
    Good morning, i need help for a dump code + immo off Nissan PN-2805F . Thank You for help
  3. #18
    Dec 2017
    I could remove secure. code 5353. the radio is not the same vehicle.
  4. #19
    Jan 2014
    Praag,Czech Republic
    Hi friends,
    I need help with Nissan HY00E PN2805F.
    Please find out the code and disable protection.
    Here's my dump from L46:https://www.dropbox.com/s/u3euo0acwh...19%20.bin?dl=0
    Thank you very much.
  5. #20
    Jan 2013
    Quote Originally Posted by josfiala View Post
    Hi friends,
    Try this 0000 pin error cleared
  6. #21
    Jan 2014
    Quote Originally Posted by geeroam View Post
    The radio cannot be turned on after recording this dump, only the clock is shown on the display.
    P.S. I need to know the code from my dump and adjust it to Secure OFF.
    The radio will be in another car and I need to test it on a desk without a car.
    Thank you.
  7. #22
    Jan 2013
    Your dump has four zeroes 0000 as the code
  8. #23
    Jan 2014
    I turn on the radio - writes WAIT after some time then writes SECURE. Code 0000 cannot be entered. Radio's on my desk, it's not in the car. Is there a solution?
  9. #24
    Dec 2012
    Try this dump, code 3399, secure off.
  10. #25
    Jan 2014
    Quote Originally Posted by andm266 View Post
    This listing has been uploaded. When connected to the car he writes PLEASE INIT. After starting the car, the situation does not change.
    There is no way to enter CODE, just PLEASE INIT. Question: is it necessary to register the car radio via a dignostic tool?
    What does PLEASE INIT mean? I turned on the radio, the vehicle started. The dump I recorded has SECERE OFF in the title.
    What is wrong? Thank you.
  11. #26
    Dec 2012
    Try connect EQ1 or EQ4 to ground, or EQ1 and EQ4.
  12. The Following User Says Thank You to andm266 For This Useful Post:
    josfiala (14th December, 2019)
  13. #27
    Jan 2014
    Notes: / I cannot test the radio in the vehicle now / On the work desk after turning on the radio Writes WAIT after a little while SECURE.
    I tried to connect both EQ1 and EQ4 to ground, then both EQ1 + EQ4 to ground. The result is the same. So WAIT and then SECURE.
    Next notes : after loading dump from DEXTER / side1 // 24c64 pin7819 ( Off 'Secure' ).rar / and connecting PIN EQ1 to ground, radio writes CODE IN and goes to insert code.
    Everything is functional. I hope in the car it will also work with EQ1 to ground. In two days I will have a car, so hopefully this solution will work in the car.
    Next notes 2 : after connecting to the car it is also necessary to connect pin EQ1 to ground. Otherwise the radio writes PLEASE INIT. After connecting EQ 1 to ground, it writes CODE IN. / consideration: for another radio you may need to connect another PIN, for example EQ3, EQ4 ... /
    Thanks to all for your help .
  14. The Following 2 Users Say Thank You to josfiala For This Useful Post:
    barto41 (11th January, 2020), hudy26 (17th March, 2020)
