Results 16 to 30 of 43
  1. #16
    Apr 2018
    Chile
    I have the same problem, it cranks, but it doesn´t start...
  2. #17
    Jun 2013
    Check the wirning under left lamp, if is ok ecu is damaged.
    Wysłane z mojego SM-G390F przy użyciu Tapatalka
  3. #18
    Jul 2018
    Hi Test or my boxer has the same codes cut out every 100 metres. Just made it home last night. Is the in for you had attached still available as I can't seem to access it? Thanks
  4. #19
    Jul 2018
    Default Sorry that should have said Hector auto correct is annoying
    Quote Originally Posted by IrishRog View Post
    Hi Hector my boxer has the same codes cut out every 100 metres. Just made it home last night. Is the in for you had attached still available as I can't seem to access it? Thanks
    Sorry that should have said hector but autocorrect caught me out
  5. #20
    Jul 2018
    Folks
    I came across this which helped me when trying to understand the Peugeot Boxer wiring
    http://www.autoelectric.ru/auto/peug...ngdiagrams.htm
  6. The Following User Says Thank You to IrishRog For This Useful Post:
    Meat-Head (12th August, 2019)
  7. #21
    Jul 2015
    My Car
    Quote Originally Posted by m0rd0k View Post
    Thanks for the photos and help. I have the same problem,and these pictures fix it. Thanks from Hungary!
    Hello friends
    Can I have the password please
  8. #22
    Oct 2015
    Poland warsaw
    many thanks, why hector is banned?!
  9. #23
    Feb 2018
    hello i have the same problem, can yours hep me please? i dont have see the rar archive
  10. #24
    Jun 2013
    Quote Originally Posted by wbart View Post
  11. #25
    Jan 2019
    Thank you Héctor, i hope it works for me...
  12. #26
    Jan 2019
  13. #27
    BusCan's Avatar
    Nov 2013
    I'm having a problem with a DCU-102
    Default code
    P0200 Default Tension Converter
    I change the CPU ca does not change anything, Transistor OK
    If a person can give me information it will be great
    Thank you
  14. #28
    I have same problem (p0200-p062b) but not damaged wire solve the problem.
    FİXED-- Change micro software and than solve the problem. If you have a questıon ask me.
  15. #29
    BusCan's Avatar
    Nov 2013
    Quote Originally Posted by mtutus View Post
    I changed ÉCU
    Thank you
  16. #30
    dehacko's Avatar
    Feb 2018
    SK
    HI
    I have the same problem car ducato does not start, DTC: P026B and P0200
    the car is already starting, only error P026B remains , everything works
