Results 1 to 12 of 12
    Apr 2020
    Toronto, Canada
    Default 2018 Honda civic 77960-TGG-A020-M2 R7F701A223
    Hello friends, I need your help to clear this crash file please.
  2. The Following User Says Thank You to Hondasilver For This Useful Post:
    speedcar (24th February, 2024)
  3. #2
    Apr 2020
    Toronto, Canada
    Any one there ?
    superjet's Avatar
    Aug 2018
    your file read bad,read it again
    Apr 2020
    Toronto, Canada
    Its the only original file i have , I had write over it with a clear file that another user sent me .
    They sent me all FF
    Do you have a clear file by any chance ?
    superjet's Avatar
    Aug 2018
    and did you try how it go?
    Apr 2020
    Toronto, Canada
    Not good, cannot get access to calibrate the ABS/VSA speed sensors .
    One member on here told me that line 00002680 has to be original
    But it did allow me to calibrate SWS , ( Seat weight sensor)
  8. The Following User Says Thank You to Hondasilver For This Useful Post:
    radiolomaster83 (24th January, 2023)
  9. #7
    superjet's Avatar
    Aug 2018
    send your srs module picture
  10. The Following User Says Thank You to superjet For This Useful Post:
    Hondasilver (9th April, 2021)
  11. #8
    magneto21's Avatar
    Jul 2016
    try this...
    manually cleared
    “The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice.”
  12. The Following 5 Users Say Thank You to magneto21 For This Useful Post:
    andresrepair (14th December, 2021), bisonte2020 (26th August, 2022), Hondasilver (9th April, 2021), superjet (10th April, 2021)
  13. #9
    Apr 2020
    Toronto, Canada
    Superjet, here are the picks for 77960-TGG-A020-M2
  14. #10
    Apr 2020
    Toronto, Canada
    Thank you Magneto21, I just programmed it with your file.
    I will let you know how it went tomorrow.
  15. #11
    Apr 2020
    Toronto, Canada
    magneto21, your manually cleared crash file worked.
    Turn it on and the Airbag light went off.
    Had to program ABS sensors and all the warning lights came off.
    I used Xprog 6.12 Clone for programming ( Read & Write)
    You're a Champ.
    Thank you
  16. The Following 2 Users Say Thank You to Hondasilver For This Useful Post:
    Diman0770 (6th November, 2022), magneto21 (10th April, 2021)
  17. #12
    Dec 2019
    how do i access this file?
