Results 1 to 7 of 7
    Dec 2013
    Default Tactix openport + PCM Flash toyota denso ecu
    hi, i need read and write toyota denso ecu ( i need only Toyota Hilux)
    i look tactrix openport http://ecutools.eu/chip-tuning/openport-20/
    with pcm flash module 35 http://ecutools.eu/chip-tuning/pcmflash/
    i can do this ecu with this products?
  2. The Following User Says Thank You to masciaro For This Useful Post:
    sparedes (8th October, 2018)
  3. #2
    CustomCars's Avatar
    Jul 2015
    Europe - PL
    You can use Tactrix + bit tools but only for VR read, to get orginal dump from server.
    Can't make ecu write or download dump from car..
    With PCM more is possible but better check coverage for models..
    Hilux Ecu possible no 175822-666 CPU 76F0040GD and 175822-887 CPU 76F0039AGD
    All brand FileService - Custom - remapping company
    POWER>DPF>EGR>KL>SCR>TVA>DTC's>Lambda>NOx>CustomSp ecialization -
    | Diesel | Bosch/Siemens SID/Denso/Delphi/Visteon/Phoenix
  4. The Following User Says Thank You to CustomCars For This Useful Post:
    CLK1201 (9th June, 2016)
  5. #3
    Dec 2013
    pcm flash says this on protocol 35
    Toyota/Lexus/Scion/Hino
    76F0038/39/40/70/85, MPC565, SH72512 CAN-bus
    76F0004/23/38/39/40, MPC565 K-Line
    76F0004/23/38/39/40 K-Line JDM
    Writing, checksum correction.
  6. #4
    you cannot read this ecu with pcmflash! only write and chkecksum.
    Sep 2016
    use k-tag/transdata
    FILE SERVICE
  8. The Following User Says Thank You to voltechcar For This Useful Post:
  9. #6
    EARTH
    Default pcmflash
    Too bad to miss activations.
    Policy does not support customers.
    Maybe it would not be good to buy more activations.
  10. #7
    peko's Avatar
    Quote Originally Posted by datapage View Post
    is totaly stupid this process ...
    if you give proove about paiement, and buy another dongle ...
    old dongle must be erased from server or tool not check activation in server ? it will be cracked ...
  11. The Following User Says Thank You to peko For This Useful Post:
    datapage (27th May, 2019)
