Results 1 to 3 of 3
    Feb 2020
    Default Yamaha Waverunner VX110 ECU Problem
    I'm in trouble with my Yamaha vx 110 of 2006 Deluxe.
    I bought a ECU on ebay a 6D3-A0 witch doesn't work good. It has good pins.
    It was spotering and misfiring between 2000 rpm and 4000 rpm after it was ok.
    But i removed the map inside to try to read it and find the problem.
    But when i tryed to write it again without changing something the checksum wasn't correct.
    Of course the program inside was bad.
    I read/write with a Piasini chinese clone.
    So i need an origine map for an ECU : Mitsubishi 6D3-A0 F8T94772. The size of the file of 512Ko (cks).
    Thank you for your help !
    Best regard's
    Laurent
    Feb 2020
    Nobody can help me with this old machine ?
    gmb45's Avatar
    Nov 2008
    park bench, hedge bottom, police cell
    =not in general chat they cant, try posting in the correct forum !!!
  4. The Following User Says Thank You to gmb45 For This Useful Post:
    laurent63 (8th March, 2020)
