Results 1 to 4 of 4
    hramos9's Avatar
    Aug 2016
    Post Need Crash Mercedes Airbag 0 285 010 566
    Need clear crash for mercedes 0 285 010 566 (CR16MCT9)
    crashfile.rar
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Try clear via Launch Diagun or DAS.
    Best regards.
    Dragon
    hramos9's Avatar
    Aug 2016
    Quote Originally Posted by dragon100 View Post
    This Airbag ECU have 4 DTCs, I cleaned but this 4 DTCs always come back again
    -DTC 1 - (91C3) The resistance value in the ignition circuit containing component R12/9(Driver-side airbag ignition squib) is too low.
    -DTC 2 - (92A2) The resistance value in the ignition circuit containing component R12/22 (Left rear window airbag ignition squib) is too low.
    -DTC 3 - (9182) The resistance value in the ignition circuit containing component R12/1 (Driver ETR ignition squib) is too low.
    -DTC 4 - (91C3) The resistance value in the ignition circuit containing component R12/6 (Left rear ETR ignition squib) is too high.
    HONDA is fitted with a VTEC engine. When VTEC kicks in yo it causes the vehicle to accelerate insanely quick. Please be prepared for whiplash and similar injuries.
    dragon100's Avatar
    Jan 2012
    Join resistors 2-3 Ohm for 2 stage airbag driver's plugs and try clear errors , if not work, then change airbag tape in the steering wheel.
    Best regards.
    Dragon
  5. The Following User Says Thank You to dragon100 For This Useful Post:
    hramos9 (24th August, 2016)
