Results 1 to 9 of 9
    mislav88's Avatar
    Mar 2011
    Default Golf 7 ABS long coding
    Hi, i have lost long coding on VW Golf7 abs, can someone reconstruct it? I dont expect it to be free, just pm me.
    Wednesday,20,July,2015,21:32:18:61290VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 15.7.1.0 (x64)
    Data version: 20150904
    www.Ross-Tech.com
    VIN: WVWZZZAUZEW296624   License Plate:
    Chassis Type: AU (5Q0)
    Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: Malfunction 0010
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    Address 01: Engine (J623-CLHA)       Labels: 04L-907-309-V1.clb
       Part No SW: 04L 906 021 M    HW: 04L 907 309 B
       Component: R4 1,6L EDC   H22 5517
       Revision: 84H22---
       Coding: 01110012032405092000
       Shop #: WSC 99999 123 12345
       ASAM Dataset: EV_ECM16TDI01104L906021M 002009
       ROD: EV_ECM16TDI01104L906021AL.rod
       VCID: 2F6DF53E76BD41663D9-807A
    1 Fault Found:
    17158 - Databus
              U1123 00 [047] - Received Error Message
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 22173 km
                        Date: 2016.07.19
                        Time: 03:06:08
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
       Part No SW: 5Q0 907 379 AA    HW: 5Q0 907 379 G
       Component: ESC           H31 0457
       Revision: 00000000    Serial number: 6025400000003B
       Coding: 000000000000000000000000000000000000
       Shop #: WSC 58299 001 1048576
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
       ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
       VCID: 7BF5116EF2456DC6C11-802E
    13 Faults Found:
    0071 - Rear Left Wheel Speed Sensor
              C101C 4A [137] - Incorrect component(s) installed
              MIL ON - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 87
                        Date: 2016.07.19
                        Time: 03:03:32
    0087 - Rear Right Wheel Speed Sensor
              C101D 4A [137] - Incorrect component(s) installed
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 87
                        Date: 2016.07.19
                        Time: 03:03:32
    8196 - Databus
              U1121 00 [009] - Missing Message
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 87
                        Date: 2016.07.19
                        Time: 03:03:32
    8278 - Control Module Incorrectly Coded
              U1014 00 [137] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 87
                        Date: 2016.07.19
                        Time: 03:03:32
    8291 - Databus
              U1123 00 [008] - Received Error Message
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 6
                        Reset counter: 127
                        Mileage: 22173 km
                        Date: 2016.07.19
                        Time: 03:04:41
    8299 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 87
                        Date: 2016.07.19
                        Time: 03:03:32
    8309 - Engine Control Module Incorrectly Coded
              P1612 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 10
                        Reset counter: 87
                        Date: 2016.07.19
                        Time: 03:03:32
    8351 - Databus
              U1122 00 [009] - Implausible Message
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 87
                        Date: 2016.07.19
                        Time: 03:03:32
    8356 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 87
                        Date: 2016.07.19
                        Time: 03:03:32
    8368 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 11
                        Reset counter: 87
                        Mileage: 22173 km
                        Date: 2016.07.19
                        Time: 03:03:47
    16390 - Display for Tire Pressure Monitoring
              C1146 02 [137] - Signal Failure
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 87
                        Mileage: 22173 km
                        Date: 2016.07.19
                        Time: 03:03:50
    32992 - Control Module for Electric Parking Brake
              C10E2 F0 [137] - RPM Sensor Implausble Signal
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 87
                        Date: 2016.07.19
                        Time: 03:03:32
    32994 - Control Module for Electric Parking Brake
              C10E2 F0 [009] - RPM Sensor Implausble Signal
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 87
                        Date: 2016.07.19
                        Time: 03:03:32
    Address 08: Auto HVAC (J301)       Labels: None
       Part No SW: 5G0 907 426 J    HW: 5G0 907 426 J
       Component: AC Manuell    H01 0503
       Revision: 00001K06
       Coding: 00020104202100001000000000000000
       Shop #: WSC 01357 011 00200
       ASAM Dataset: EV_ACManueBHBVW37X 002017
       ROD: EV_ACManueBHBVW37X_VW37.rod
       VCID: 326BFC4A658F6C8E527-8067
       Fresh Air Blower Front:
       Refrigerant Pressure And Temperature Sender:
    No fault code found.
    Address 09: Cent. Elect. (J519)       Labels: None
       Part No SW: 5Q0 937 084 AC    HW: 5Q0 937 084 AC
       Component: BCM MQBAB M   H16 0124
       Serial number: 00011403100176
       Coding: 00000842C241005B4FE44000000403081000000000000000000000000000
       ASAM Dataset: EV_BCMCONTI 012001
       ROD: EV_BCMBOSCH_VW37.rod
       VCID: 79F90B66F8795FD6D3D-802C
       Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A
       Component: WWS    121111  042 0551
       Serial number:         121208023236
       Coding: 0E4DD5
    1 Fault Found:
    197644 - Control Circuit for Fuel Tank Flap
              B1263 01 [009] - Electrical Failure
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 87
                        Mileage: 1048574 km
                        Date: 2000.00.00
                        Time: 00:00:00
    Address 15: Airbags (J234)       Labels: 5Q0-959-655.clb
       Part No SW: 5Q0 959 655 C    HW: 5Q0 959 655 C
       Component: AirbagVW20    011 0361
       Serial number: 003F5R01YBU/
       Coding: 98CCC000000000005C0000CF004800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 408FA682DB23CE1ED43-8015
       Crash sensor for side airbag; driver side:
       Subsystem 1 - Part No SW: -----------    HW: 480 000 201 13
       Component: SideSensor_Df  001 0887
       Serial number: 35767000000EF41C7C07
       Coding: 2D2D2D
       Crash sensor for side airbag; passenger side:
       Subsystem 2 - Part No SW: -----------    HW: 480 000 201 13
       Component: SideSensor_Pf  001 0887
       Serial number: 358670000003A2745C0T
       Coding: 2D2D2D
       Crash sensor for side airbag; rear driver side:
       Subsystem 3 - Part No SW: -----------    HW: 480 400 301 13
       Component: SideSensor_Dr  001 6149
       Serial number: 3516502BD0D5D605B1CQ
       Coding: 2D2D2D
       Crash sensor for side airbag; rear passenger side:
       Subsystem 4 - Part No SW: -----------    HW: 480 400 201 13
       Component: SideSensor_Pr  001 6149
       Serial number: 3526502BB0D5D603E2CR
       Coding: 2D2D2D
       Crash sensor for front airbag; driver side:
       Subsystem 5 - Part No SW: -----------    HW: 480 401 512 12
       Component: FrontSensor_D  001 6149
       Serial number: 3556502A90CD5EC0F18$
       Coding: 2D2D2D
    Address 16: Steering wheel (J527)       Labels: 5Q0-953-549.clb
       Part No SW: 5Q0 953 507 AM    HW: 5Q0 953 549 A
       Component: Lenks. Modul  007 0070
       Revision: --------    Serial number: 07011308490408
       Coding: 1704
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_SMLSKLOMQB 009001
       ROD: EV_SMLSKLOMQB.rod
       VCID: 8109E38610A987161BD-80D4
    Address 17: Instruments (J285)       Labels: None
       Part No SW: 5G0 920 961 A    HW: 5G0 920 961 A
       Component: KOMBI         204 3390
       Coding: 27A41A002780260001882A01040000
       Shop #: WSC 03020 425 00000
       ASAM Dataset: EV_DashBoardJCIMQBAB 008011
       ROD: EV_DashBoardJCIMQBAB.rod
       VCID: 285F1E225353165EFC3-807D
    3 Faults Found:
    16776960 - Databus
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 87
                        Mileage: 22173 km
                        Date: 2016.07.19
                        Time: 03:03:31
    16776961 - Databus
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 87
                        Mileage: 22173 km
                        Date: 2016.07.19
                        Time: 03:03:31
    16777020 - Function Restricted due to Interrupted Communications
              U1110 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 87
                        Mileage: 22173 km
                        Date: 2016.07.19
                        Time: 03:03:34
    Address 19: CAN Gateway (J533)       Labels: None
       Part No SW: 5Q0 907 530 D    HW: 5Q0 907 530 D
       Component: GW MQB Low    120 1109
       Revision: --------    Serial number: 0000237325
       Coding: 030000040B087300EF000048080F00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 006010
       ROD: EV_GatewLear_VW37.rod
       Generator:
       Battery Monitoring Control Module:
       Subsystem 2 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
       Component: J367-BDMHella  H03 8042
       Serial number: 3977378601
    Address 42: Door Elect, Driver (J386)       Labels: None
       Part No SW: 5Q0 959 393 A    HW: 5Q0 959 393
       Component: TSG FS        012 0006
       Serial number: 09121200090085
       Coding: 003003208000040000001000
       ASAM Dataset: EV_DCUDriveSideEWMINKLO 006003
       ROD: EV_DCUDriveSideEWMAXCONT.rod
       VCID: 3D71DF76ACD1A3F6BF5-8068
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
       Component: Fond FHSG DRV  007 0002
       Serial number: 00000000000000524461
       Coding: 010000
    Address 44: Steering Assist (J500)       Labels: 5Q0-909-144.clb
       Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
       Component: EPS_MQB_ZFLS  119 1021
       Coding: 81
       ASAM Dataset: EV_SteerAssisMQB 008022
       ROD: EV_SteerAssisMQB.rod
    2 Faults Found:
    19716 - Databus
              U1123 00 [009] - Received Error Message
                 Freeze Frame:
                        Fault Priority: 6
                        Reset counter: 87
                        Mileage: 22173 km
                        Date: 2016.07.19
                        Time: 03:03:34
    20228 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Reset counter: 87
                        Mileage: 22173 km
                        Date: 2016.07.19
                        Time: 03:03:34
    Address 52: Door Elect, Pass. (J387)       Labels: None
       Part No SW: 5Q0 959 392 A    HW: 5Q0 959 392
       Component: TSG BFS       012 0006
       Serial number: 01121200011406
       Coding: 003001208000040000801000
       ASAM Dataset: EV_DCUPasseSideEWMINKLO 006003
       ROD: EV_DCUPasseSideEWMAXCONT.rod
       VCID: 3C77D272B7CBAAFE88B-8069
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
       Component: Fond FHSG PSG  007 0002
       Serial number: 00000000000000497095
       Coding: 090000
    Address 5F: Information Electr. (J794)       Labels: None
       Part No SW: 5G0 035 867     HW: 5G0 035 867
       Component: MU-E--ER      615 5561
       Serial number: 20111200010132
       Coding: 02730000FF0000004011000100000000000000040000010000
       ASAM Dataset: EV_MUEnt4CLGE 001025
       ROD: EV_MUEnt4CLGE_VW37.rod
       VCID: E9D9DB2608D96F56A3D-80BC
    End   ---------------------------------------------------------------------
    rob h's Avatar
    May 2011
    That happens when you plug in a cluster that not belongs with the abs unit.
    Only the dealer can do this abs recoding online,
    mislav88's Avatar
    Mar 2011
    done it offline with vcds, not a single dtc left
    Jul 2014
    Quote Originally Posted by mislav88 View Post
    How did you fixed?
    mislav88's Avatar
    Mar 2011
    ross tech support calculated few possible codings for me, one of them worked perfectly
  6. The Following User Says Thank You to mislav88 For This Useful Post:
    Atex31 (21st December, 2016)
    Portugal
    Hello mislav88
    what was necessary?
    DK Veteran daniel guerra's Avatar
    Getting a original VCDS and ask for help on VCDS forums.
  9. The Following User Says Thank You to daniel guerra For This Useful Post:
    mislav88 (3rd January, 2017)
  10. #8
    Portugal
    Hi!!
    I got an original but after ask support they say that can not calculate
  11. #9
    Feb 2016
    I have the same Golf VII problem.
    i did the odis online encoding but it didn't help.
    Address 03: ABS Brakes Labels: 5Q0-907-379-IPB-V1.clb
    Control Module Part Number: 5Q0 907 379 AC HW: 5Q0 907 379 D
    Component and / or Version: ESC H75 0437
    Software Coding: 01FA62A120270A6F0379060701C82580460450C06080A4F3F4 48F024C0
    Work Shop Code: WSC 00046 000 00000
    ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020 (VW37)
    ROD: EV_Brake1UDSContiMK100IPB_008.rod
    VCID: 7DF622B6EC6A2EA982-8028
    7 Faults Found:
    0071 - Rear Left Wheel Speed ​​Sensor
    C101C 4A [137] - Incorrect component (s) installed
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 23
    Mileage: 104720 km
    Date: 2020.06.03
    Time: 12:25:40
    0087 - Rear Right Wheel Speed ​​Sensor
    C101D 4A [137] - Incorrect component (s) installed
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 23
    Mileage: 104720 km
    Date: 2020.06.03
    Time: 12:25:40
    8196 - Databus
    U1121 00 [137] - Missing Message
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 23
    Mileage: 104720 km
    Date: 2020.06.03
    Time: 12:25:40
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 23
    Mileage: 104720 km
    Date: 2020.06.03
    Time: 12:25:51
    32830 - Parking Brake Motors
    C10E1 29 [137] - Signal Implausible
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 23
    Mileage: 104720 km
    Date: 2020.06.03
    Time: 12:25:40
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 23
    Mileage: 104720 km
    Date: 2020.06.03
    Time: 12:25:41
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 23
    Mileage: 104720 km
    Date: 2020.06.03
    Time: 12:25:41
